Open Form Before Document Closes
tim.schroeder3K47N
tim.schroeder3K47N
Needless to say, I am new at using ilogic....I am looking on how to use ilogic to open my form when I select the close button.  I am using a form to update the required iproperties.
thanks.
Curtis_Waguespack
Hi @tim.schroeder3K47N,
There is a Close Document event trigger, but it will cause problems with a form, as it will show the form after the close. I would recommend using the Before Save even trigger to show your form.
I typically use the After Open and Before Save (sometimes both) to bring up forms for iProperties, etc.
Work with event triggers in iLogic
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2015...
I hope this helps.
Curtis
tim.schroeder3K47N
Thanks Curtis...I appreciate your reply.  That makes sense and works for me.
regards,
Tim
