- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi, i am publishing a selected face from a normal part with the API to a dxf File. I am using this code because doing it with an ini File does not works in this context (it's not a SheetMetal Part):
Dim Cm As CommandManager = InventorApp.CommandManager Cm.PostPrivateEvent(PrivateEventTypeEnum.kFileNameEvent, mPath.ToString) Dim oCtrlDef As ButtonDefinition = Cm.ControlDefinitions.Item("GeomToDXFCommand") oCtrlDef.Execute()
This works, but i would like to set the Version of ACAD for the dxf File. Is there a possibility to do this with the API?
Regards Martin
Martin Winkler
CAD Developer
Did you find this post helpful? Feel free to like this post.
