Properties Tab ~ Inventor 2020
leblanc2024
Message 1 of 15
leblanc2024
Hello I had a Properties Tab pop up on my screen and I can't remove it. The close tab (X) doesn't work. Does anyone know where I can deactivate this?
Ivon
"You don't know if you can unless you try!"
Replies (14)
Message 2 of 15
DRoam
What made this pop up? Were you doing some automation/iLogic or just using built-in commands?
EDIT: Also, I assume you've tried restarting?
Message 3 of 15
YuhanZhang
You can try to start the command for creating Hole/Extrude feature, then close the Properties panel, if this does not solve the problem please just restart Inventor. If you have reproducible steps for this issue please let me know, I can log a defect for this.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
Message 4 of 15
leblanc2024
@DRoam and @YuhanZhang ,
I was changing the properties of a line in an idw but hit escape to exit the change.
I changed my mind and didn't want to continue with that change.
I had also tried restarting this didn't work the first restart but after a crash it was gone.
The crash happened without a crash report being generated.
Sorry @YuhanZhang I was unable to use your suggestion to fix this.
If it happens again I'll let you know.
Ivon
Message 5 of 15
YuhanZhang
Is that Properties panel invoked from the edit of a line in drawing? I thought it was a properties panel for create/edit an Extrude/Hole etc. features. Can you create a video for your steps to display the properties panel again?
Rocky Zhang
Inventor API PD
Autodesk, Inc.
Message 6 of 15
leblanc2024
@YuhanZhang,
I'll try to reproduce the error (if possible).
Ivon
Message 7 of 15
MalcMaltby
Observer
Observer
I have experienced this anomaly once or twice too, but have always just restarted Inventor and carried on, as that seemed to clear things up.
Probably of little help either as I cannot remember the sequence of events. However, I have compiled an image of what I experienced in case it helps?
For reference I am using;
Autodesk Inventor Professional 2020 64 bit edition build 168 release 2020.0.1
Using normal commands as well, no ilogic etc.
Message 8 of 15
leblanc2024
Thanks @MalcMaltby.
I just learned to live with it for now.  I embed it into the model tab until it goes away.
One day I'll catch the bug that causes it (maybe?)
Ivon
Ivon
Message 9 of 15
rbrown
I have this issue as well and hope to get a solution soon. It's annoying and gets in the way of the Model/Vault tabs.
Message 10 of 15
cjvanwyk
Community Visitor
Community Visitor
I have a similar problem. After I use the geometric tolerance or a welding symbol the window stays. You have to close inventor to get rid of it. I do not want to close the program every time this happen. See picture.
How do you cure this?
Message 11 of 15
leblanc2024
@cjvanwyk,
This problem hasn't happened since I have upgraded to 2021.  But as a work around I dragged the properties window to the model tree and embedded it there.  It was out of the way until a restart. It isn't a perfect solution aside from upgrading.  Hope this helps.
Ivon
Message 12 of 15
rbrown
I have been able to get rid of through the advice of one of the posts above. I just start a new .ipt, and create a sketch then perform an extrude feature. Once I close the extrude pop-up window, it eliminates the property window/tab. Hope that helps.
Message 13 of 15
YuhanZhang
Hi Ivon,
Can you remember how to steadily reproduce the problem? If you have steps to reproduce the problem I will ask our dev to look into it.
Rocky Zhang
Inventor API PD
Autodesk, Inc.
Message 14 of 15
leblanc2024
Hello @YuhanZhang (Rocky),
Since I have upgraded to 2021 this issue hasn't happened. I was just trying to help @cjvanwyk to let him know what I did in the past. So sorry I can no longer reproduce the issue.
Ivon
Message 15 of 15
rhenstenburg
