Need some help getting parameters in an Excel file into Assembly part parameters
matthew_neesley
matthew_neesley
I have an excel document with numbers representing "Z" values in one column.  The next column has the names of the parts in an assembly.  I thought I had it working, but it turns out the darn parts aren't updating to the differing values, they are ALL going to one value...WTH??
Another thing I don't know how to do is format this whole thing for how many instances are in each file.  Could someone help me out with this?
Here's the code I'm using:
Parameter("Copy of 2018_TOS_Insert-Standard Duty Support:1", "TOS") = GoExcel.CellValue("Resize all Legs.xlsx", "Sheet1", "B1")
Parameter("Copy of 2018_TOS_Insert-Standard Duty Support:2", "TOS") = GoExcel.CellValue("Resize all Legs.xlsx", "Sheet1", "B2")
Parameter("Copy of 2018_TOS_Insert-Standard Duty Support:3", "TOS") = GoExcel.CellValue("Resize all Legs.xlsx", "Sheet1", "B3")
Parameter("Copy of 2018_TOS_Insert-Standard Duty Support:4", "TOS") = GoExcel.CellValue("Resize all Legs.xlsx", "Sheet1", "B4")
Parameter("Copy of 2018_TOS_Insert-Standard Duty Support:5", "TOS") = GoExcel.CellValue("Resize all Legs.xlsx", "Sheet1", "B5")
Parameter("Copy of 2018_TOS_Insert-Standard Duty Support:6", "TOS") = GoExcel.CellValue("Resize all Legs.xlsx", "Sheet1", "B6")
Parameter("Copy of 2018_TOS_Insert-Standard Duty Support:7", "TOS") = GoExcel.CellValue("Resize all Legs.xlsx", "Sheet1", "B7")
Parameter("Copy of 2018_TOS_Insert-Standard Duty Support:8", "TOS") = GoExcel.CellValue("Resize all Legs.xlsx", "Sheet1", "B8")
Parameter("Copy of 2018_TOS_Insert-Standard Duty Support:9", "TOS") = GoExcel.CellValue("Resize all Legs.xlsx", "Sheet1", "B9")
Parameter("Copy of 2018_TOS_Insert-Standard Duty Support:10", "TOS") = GoExcel.CellValue("Resize all Legs.xlsx", "Sheet1", "B10")
Parameter("Copy of 2018_TOS_Insert-Standard Duty Support:11", "TOS") = GoExcel.CellValue("Resize all Legs.xlsx", "Sheet1", "B11")
Parameter("Copy of 2018_TOS_Insert-Standard Duty Support:12", "TOS") = GoExcel.CellValue("Resize all Legs.xlsx", "Sheet1", "B12")
So basically I need for that to run for as many times as there are legs, with the "Support:1" etc. simply incrementing by one each time, and the same thing for the "B-" number at the very end.  Thanks so very much in advance, this will be a HUGE timesaver for my company!
matthew_neesley
I just came to the ugly realization that this likely the wrong road.  These are all Factory Utilities Assets...which means that complex API rabbit-hole gain.
https://forums.autodesk.com/t5/inventor-customization/wild-ilogic-asset-idea-insert-connect-asset-at...
chandra.shekar.g
Autodesk Support
Autodesk Support
@matthew_neesley ,
Hoping that below iLogic code may be helpful.
myparam = InputBox("Enter total support legs", "Leg support number", "10")
For a = 1 To Convert.ToInt16(myparam)
	 'Messagebox.Show(a.ToString)
	 Parameter("Copy of 2018_TOS_Insert-Standard Duty Support:" + a.ToString, "TOS") = GoExcel.CellValue("Resize all Legs.xlsx", "Sheet1", "B" + a.ToString)
Next
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
matthew_neesley
Thanks very much for your contribution.  I ended up doing it with revised code from one of your colleagues.
