iLogic to Change Browser Name of Part to Part Number
felix.cortes5K3Y2
felix.cortes5K3Y2
Hi Forum,
I want to add a part using the following command provided by inventor:
Dim componentA = Components.AddContentCenterPart("occNameA", "Fasteners:Bolts:Hex Head", "AS 1427 - Metric",
                                                 "M3 x 16", position := Nothing, grounded := False,
                                                 visible := True, appearance := Nothing)
However, I'd like to change the browser name to the Part Number given in the description. I've read through the post named: Using iLogic to Rename Browser Nodes. However, that post renames all of the browser items and I wouldn't want to do that.
How can I name the component on the browser to it's correct Part Number?
Best regards,
Felix
HermJan.Otterman
did you try:
 ComponentA.name = "partnumber_1"   ..??
(the name must be unique!)
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
felix.cortes5K3Y2
That didn't seem to work since the name is Read Only. I can retrieve the part number by:
Dim PartNumber As String = iProperties.Value("occNameA", "Project", "Part Number")
How can I set the browser name to the PartNumber?
Best regards,
Felix
JaneFan
Hey @felix.cortes5K3Y2 ,
It seems like renaming occurrence name to part number can meed your needs:
componentA.Occurrence.Name = iProperties.Value("occNameA", "Project", "Part Number")
Jane Fan
Inventor/Fusion QA Engineer
