Hi everyone,
I have a problem in drawing. I have a part with a series of features. The number of features change with the height of the panel.
In drawing when I add dimension to feature I saw correctly:
When I change the height of panel the dimensions aren't correctly like:
The dimension (90,00) must be connect point 2 not point 1.
I possibile to manage them with iLogic? Have you got any solution for me?
Thanks.
Please provide non confidential drawing to test the feasibility.
Thanks and regards,
I create similar part with series of features. The problem is the same. If you modify the parameter "Altezza", you can show on drawing the problem that I mean.
Thanks for your support.
