Inventor Nesting materials - finished side(s)
BrandonBG
BrandonBG
Looking for ideas on how to handle A-sides/one-sided material in Inventor Nesting.
Flipping the material is the issue that's keeping me from diving into Inventor Nesting.
Our wood shop uses several different material orientations: one finished side, two finished sides, no finished sides, or two differently finished sides.
I haven't been able to figure out an easy workflow for handling 4+ materials with necessary up and down orientations.
Brandon
If you want to do them all in the same .inest file you're going to have to define a different packaging for each orientation. Inventor Nesting pulls information from the material and thickness to determine which packaging to put the part in. You could either define a different material for each orientation or a slightly different thickness for each. The A side should always be nested up unless "flip" is enabled for that material. Hope this helps!
p.sangeetaKZZMH
Hi Team,
Can anyone suggest for Inventor Nesting Programming files/links/videos (VBA/VB.net/C#).
Thanks in advance
