Inventor Change Sheet Metal Default Flange And Hole Size
JH81
JH81
Moved from older post: Convert to Sheet Metal default settings
Is there any way of changing the default flange size (currently set to 25mm) and default hole size (currently 3mm)?
kelly.young
Autodesk Support
Autodesk Support
Hello @JH81 the preset for Hole Diameter and Flange Distance are hard coded but something that just came out with 2019 was the ability to set Hole Presets.
Using the New Autodesk Inventor 2019 Hole Presets
It might be possible as a workaround with iLogic but I haven't seen anything like that yet.
Hope that helps!
Please select the Accept as Solution button if a post solves your issue or answers your question.
