Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Inventor 2020.2.1 - iLogic Insert Sketched Symbol to Sheet
6 REPLIES 6
MairA_DUKA
1117 Views, 6 Replies
Hello
I have written this code to insert a sketched symbol to the sheet, but on the red line I will riceive an error like this:
I want add the sketched symbol directly ton the sheet (not on a view).
What is wrong?
Sub Main()
	Try
		Break
		Dim oDoc As DrawingDocument
		oDoc = ThisDoc.Document
		Dim oSketchSymLib As SketchedSymbolDefinitionLibrary
		oSketchSymLib = oDoc.SketchedSymbolDefinitions.SketchedSymbolDefinitionLibraries.Item("Simboli")
		Dim oSSDEf As SketchedSymbolDefinition
		oSSDEf = oDoc.SketchedSymbolDefinitions.AddFromLibrary(oSketchSymLib, "Note - Codice articolo LEFT-HAND", True)
		'Obtain a reference to the desired sketched symbol definition.
		Dim oSketchedSymbolDef As SketchedSymbolDefinition
		oSketchedSymbolDef = oDoc.SketchedSymbolDefinitions.Item("Note - Codice articolo LEFT-HAND")
		Dim oSheet As Sheet = oDoc.ActiveSheet
		'Create insertion point, coordinates - in cm
		Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
		Dim oInsertionPoint As Point2d = oTG.CreatePoint2d(10, 10)
		'Add an instance of the sketched symbol definition to the sheet.
		Dim oSketchedSymbol As SketchedSymbol
		oSketchedSymbol = oSheet.SketchedSymbols.Add(oSketchedSymbolDef, oInsertionPoint, 0, 1, Nothing)
	Catch ex As Exception
		MessageBox.Show(ex.Message, "Error iLogic-Rule Check_left-right-hand_part")
	End Try
End Sub
6 REPLIES 6
Hi @MairA_DUKA
Try this version that breaks try/catch down into smaller bites, it might tell you where the problem is.
I hope this helps.
Curtis
Sub Main()
	Break
	Try
		MessageBox.Show("Error getting symbol library: " & vbLf & ex.Message)
	End Try
	Try
		MessageBox.Show("Error adding symbol from library: " & vbLf & ex.Message)
	End Try
	Try
		MessageBox.Show("Error getting symbol definition: " & vbLf & ex.Message)
	End Try
	Try
		oSketchedSymbol = oSheet.SketchedSymbols.Add(oSketchedSymbolDef, oInsertionPoint, 0, 1,)
		MessageBox.Show("Error adding symbol to sheet: " & vbLf & ex.Message)
	End Try
End Sub
rhasell
in reply to: MairA_DUKA
Hi
I can share my code with you.
@Curtis_Waguespack, Thanks for the error checking ideas.
'Get the Note refence Symbol from the library
'Insert it into the drawing
'A duplicate check done, for both Resources and Drawing
'---0o0---
Dim oDrawDoc As Inventor.DrawingDocument = ThisApplication.ActiveDocument
Dim SourceFile As String = "d:\Data\TEMPLATES\SYMBOLS\Drawing Symbols.idw"
            strSourceIDW = ThisApplication.Documents.Open(SourceFile, False)
            Dim symbolDef As SketchedSymbolDefinition
            For Each symbolDef In strSourceIDW.SketchedSymbolDefinitions
				If (StrComp(symbolDef.Name, "N_NOTES-X##", vbTextCompare) = 0) Then
                    CopyFrom = symbolDef.CopyTo(oDrawDoc, True)
            Next
            strSourceIDW.Close()
'Insert The Symbol
        Dim oSheet As Sheet = oDrawDoc.ActiveSheet
		Dim oSketchedSymbolDef As SketchedSymbolDefinition = oDrawDoc.SketchedSymbolDefinitions.Item("N_NOTES-X##")
		For Each actualSymbol As Inventor.SketchedSymbol In oDrawDoc.ActiveSheet.SketchedSymbols
			' If sketched symbol is found
			If (actualSymbol.Name = "N_NOTES-X##") Then
				Return
			Next
		Dim oTransGeom = ThisApplication.TransientGeometry
        Dim oInsertionPoint As Point2d = oTransGeom.CreatePoint2d(72.1, 57.4)
		Dim oSketchedSymbol As SketchedSymbol= oSheet.SketchedSymbols.Add(oSketchedSymbolDef, oInsertionPoint, 0, 1, Nothing)
oSketchedSymbol.Static = True
'Done
Reg
2025.1.2
Please Accept as a solution / Kudos
Hello
I have tried your code, but i receive this error:
on this line:
MairA_DUKA
in reply to: rhasell
Now I have tried your code but I will receive also an error on the blue line:
rhasell
Hi
Is it possible that there is a typo in the symbol name?
Reg
2025.1.2
MairA_DUKA
I have solved the Problem with this code:
Sub Main()
Try
Break
Dim oPromptStrings As String() = {"Test"}
oSketchedSymbol = oSheet.SketchedSymbols.Add(oSketchedSymbolDef, oInsertionPoint, 0, 1, oPromptStrings)
End Try
End Sub
