ILogic-save as Rule
ILogic-save as Rule
Nauld1
Message 1 of 8
ILogic-save as Rule
Nauld1
So I've come up with the following iLogic rule
New_Name = InputBox("Enter New File Name", "Save as", "Name")
ThisDoc.Document.SaveAs(New_Name , True)
 But it's not working. I also wanted to add a way to choose a file path if possible.
Replies (7)
Message 2 of 8
Nauld1
I found the answer:
'define the active document
oDoc = ThisDoc.Document
CurrentFileName = ThisDoc.PathAndFileName(False)
'create a file dialog box
Dim oFileDlg As inventor.FileDialog = Nothing
InventorVb.Application.CreateFileDialog(oFileDlg)
Dim Filetype As String
'check file type and set dialog filter
If oDoc.DocumentType = kPartDocumentObject Then
    oFileDlg.Filter = "Autodesk Inventor Part Files (*.ipt)|*.ipt"
    Filetype = ".ipt"
ElseIf oDoc.DocumentType = kAssemblyDocumentObject Then
    oFileDlg.Filter = "Autodesk Inventor Assembly Files (*.iam)|*.iam"
    Filetype = ".iam"
ElseIf oDoc.DocumentType = kDrawingDocumentObject Then
    oFileDlg.Filter = "Autodesk Inventor Drawing Files (*.idw)|*.idw"
    Filetype = ".idw"
'set the directory to open the dialog at
oFileDlg.InitialDirectory = ThisDoc.WorkspacePath()
'set the file name string to use in the input box
oFileDlg.FileName = ThisDoc.FileName(False) 'without extension
'work with an error created by the user backing out of the save
oFileDlg.CancelError = True
On Error Resume Next
'specify the file dialog as a save dialog (rather than a open dialog)
oFileDlg.ShowSave()
'catch an empty string in the imput
If Err.Number <> 0 Then
    'MessageBox.Show("No File Saved.", "iLogic: Dialog Canceled")
ElseIf oFileDlg.FileName <> "" Then
    MyFile = oFileDlg.FileName
    'save the file
    oDoc.SaveAs(MyFile, False) 'True = Save As Copy & False = Save As
    NewDocPathName = ThisDoc.PathAndFileName(False)
    'open original drawing
    oDestinationDoc = ThisApplication.Documents.Open(CurrentFileName & ".idw")
    oDestinationDoc.saveas(NewDocPathName & ".idw",False)
    oDestinationDoc.Close
    'open new drawing
    oDestinationDoc = ThisApplication.Documents.Open(NewDocPathName & ".idw")
    Dim oDocDescriptor As DocumentDescriptor
    oDocDescriptor = oDestinationDoc.ReferencedDocumentDescriptors.Item(1)
    Dim oFileDescriptor As FileDescriptor
    oFileDescriptor = oDocDescriptor.ReferencedFileDescriptor
    oFileDescriptor.ReplaceReference(NewDocPathName & Filetype)
    oDestinationDoc.Update()
    oDestinationDoc.Save
Message 3 of 8
Owner2229
Hi, you can do so like this:
Dim oDoc As Inventor.Document = ThisApplication.ActiveDocument
Dim FName As String = oDoc.FullFileName
Dim FNP As Integer = InStrRev(FName, "\", -1)
Dim oPath As String = Left(FName, FNP)
Dim oNewName As String = InputBox("Enter New File Name", "Save as", "Name")
' If the user closes the input box, then stop the function If oNewName = vbNullString Then Exit Sub Dim oType As String Select Case oDoc.DocumentType Case kPartDocumentObject: oType = ".ipt" Case kAssemblyDocumentObject: oType = ".iam" Case kDrawingDocumentObject: oType = ".idw" End Select oDoc.SaveAs(oPath & oNewName & oType, True)
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Message 4 of 8
Hello, I wan't to do the same, but i wan't to know in witch folder I'm going to put the Part.
I have created a tube configurator and when I run the rule i wan't to first save(-as) the part and then edit the part with a Form that can chance the parameters.
Do you know more about this?
MVG thomas de Vries
Message 5 of 8
aronmatheus
Hi @Nauld1. Does this macro have to increase the ipt files save in the same folder?
Message 6 of 8
Chris_TPR
Is there a way to "save as" a list of files?
I am having to create pipe spool tags to be laser cut, and they are in the hundreds at times. I have a rule in the template set up to create a variable parameter for etching the spool number via the filename.
Currently I have been saving as XXXX.ipt one at a time, loading them into an assembly and batch export DXF. This is reasonably efficient but if there was a way to just input the data and automate the rest, it would make my life a lot easier. I can't find any info close enough to what I want to do for me to be able to make that happen with my limited coding knowledge.
I would prefer to be able to save as using one of the following:
1. A list from an excel sheet.
2. List them in the rule (it's not something I'd have tomultiple times a day, so using the rule as a "one off" isn't an issue)
3. List them separated by comma in a dialogue box.
Any help would be appreciated!
Message 7 of 8
Chris_TPR
Disregard my question.
I used ChatGPT and after a few back and forths it gave me a working code.
Dim fileList As List(Of String) = New List(Of String) From {"Part1.ipt", "Part2.ipt", "Part3.ipt"} ' Replace with your own list of file names
Dim doc As PartDocument = ThisApplication.ActiveDocument
For Each fileSuffix As String In fileList
doc.SaveCopyAs(doc.FullFileName.Replace(".ipt", "_" & fileSuffix & ".ipt"), True)
Next
I am very impressed.
Message 8 of 8
Victor.Tuguinay
Can it be done without opening a file dialogue box? It will just save directly to a predetermined file path?
