iLogic sketch text
iLogic sketch text
mk92
iLogic sketch text
mk92
i want to iterate through the text boxes in my sketch. Is this possible?
I tried this:
Dim oDoc As PartDocument
oDoc = ThisDoc.Document
Dim oSketch As PlanarSketch
oSketch = oSketch.Item(3)
Dim oTextBox As TextBox
oTextBox = oSketch.TextBoxes
            For Each oTextBox In oSketch.Item(3)
				i = i+1
	   Next
You can iterate the textbox with the following snippet code.
Dim oPartDoc As PartDocument
Dim oTextbox As TextBox
    Set oPartDoc = ThisApplication.ActiveDocument
Dim oCd As ComponentDefinition
For Each oCd In oPartDoc.ComponentDefinitions
    For Each oSketch In oCd.Sketches
        For Each oTextbox In oSketch.TextBoxes
            MsgBox oTextbox.Text 'For each textbox available in the sketch a message box will popup
        Next
    Next
Next
I you found this was helpful please accept this as solution / Press the Kudos button below Smiley Wink.
Cheers,
SK.
mk92
Thank you for your reply.
If i use it in my rule i get an error:
Error on line 18: "TextBox" is ambiguous. Imported from the namespaces or types "Inventor, System.Windows.Forms".
If i try to Import the Windows forms the error still exists.
Any ideas?
mk92
Got it!
Dim oTextbox As Inventor.TextBox
Solves the error!
I guess only 15 line are there in the code. I don't know how you got error in line 18 did you modified the code?
I got error in line 3 due to set method used in the code so I removed it.
It works fine for me. What version of inventor are you using?
            MsgBox (oTextbox.Text) 'For each textbox available in the sketch a message box will popup
        Next
    Next
Next
Please ignore my previous post.
Cheers,
SK.
