iLogic rule to change parts list style
I need an ilogic rule to autmoatically change the style of the parts list in a drawing file.
The parts list style already exist in the drawing.
I search on this forums, but I'm not a specialist.
Could someone help me ?
Thanks in advance. Vincent
That's the line you're looking for:
oPartsList.Style = oDrawDoc.StylesManager.PartsListStyles.Item("PartsList(nameofthepartlist)")
Here's the rule i use. Of course you'll have to tweak it a little bit (name of partlist):
Dim openDoc As Document
openDoc = ThisDoc.Document
'Dim docFile As Document
If openDoc.DocumentType = 12292 Then
    'Look For the model referenced within the drawing. End the Rule If the drawing Is empty.
    Dim MDocFile As Document
    If ThisDoc.ModelDocument IsNot Nothing Then
         MDocFile = ThisDoc.ModelDocument
         Else
         MessageBox.Show("It is forbiden to perform this action with an empty drawing", "Export error")
         Return
    'assumes a drawing document is active.
    Dim oDrawDoc As DrawingDocument
    oDrawDoc = ThisApplication.ActiveDocument
    'Set a reference to the active sheet.
    Dim oSheet As Sheet
    oSheet = oDrawDoc.ActiveSheet
    'Look for partlist within drawing. End rule, if it doesn't exist.
    'say there is a Partslist on the sheet.
    Dim oPartslist As PartsList
    oPartslist = oSheet.PartsLists(1)
    If oSheet.PartsLists(1) IsNot Nothing Then
        'set parts list to a specific style
        oPartsList.Style = oDrawDoc.StylesManager.PartsListStyles.Item("PartsList(nameofthepartlist2)")
    Else
    MessageBox.Show("You must have a valid Drawing document open before using this code!", "File Type Mismatch!")
Hi streharg,
Thanks you very much for your reply. It works fine !
Regards.
Eddimeister
Hey Guys...
This is the closest I've foundto Changing the Direction of a Table from TopDownDirection to BottomUpDirection...
I cant figure out the syntax... Can any one assist..!!!
Help..
Eddy
Curtis_Waguespack
Hi edmarshall35 ,
This should work.
I hope this helps.
Curtis
If openDoc.DocumentType <> kDrawingDocumentType Then
	'End the Rule If the drawing Is empty.
    Else
         MessageBox.Show("No Model Reference Found.", "iLogic")
         Return 'exit rule
    Dim oSheet As Sheet
    If oPartslist IsNot Nothing Then
'      'toggle parts list heading placement
'	  If oPartsList.HeadingPlacement = oPartsList.HeadingPlacement.kHeadingAtBottom Then
'		oPartsList.HeadingPlacement = oPartsList.HeadingPlacement.kHeadingAtTop
'	  Else
'		oPartsList.HeadingPlacement = oPartsList.HeadingPlacement.kHeadingAtBottom
'	  End If
      'toggle parts list direction
	  If oPartsList.TableDirection = oPartsList.TableDirection.kBottomUpDirection Then
		oPartsList.TableDirection = oPartsList.TableDirection.kTopDownDirection
	  Else
Else
    MessageBox.Show("This is not a drawing file.", "iLogic")
