ILogic: how to query which environment I am in
SOMAR_engineering
SOMAR_engineering
To all:
How, using iLogic, would I determine which enviroment I am in.  For instance, whether I am in the sketch environment, part environment, or assembly environment.
Thanks in advance for any help.
Curtis_Waguespack
Hi maweilian,
Here is a quick example:
Dim oDoc As Document
oDoc = ThisDoc.Document
If oDoc.DocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject  Then
	If Typeof ThisApplication.ActiveEditObject Is Sketch Then
	MessageBox.Show("You have a sketch active in a part file.", "iLogic")
	Else
	MessageBox.Show("This is a part file.", "iLogic")
Else If oDoc.DocumentType = Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then
	MessageBox.Show("You have a sketch active in an assembly file.", "iLogic")
	Else
	MessageBox.Show("This is an assembly file.", "iLogic")
Else If oDoc.DocumentType = Inventor.DocumentTypeEnum.kDrawingDocumentObject Then
	MessageBox.Show("You have a sketch active in a drawing file.", "iLogic")
	Else
	MessageBox.Show("This is a drawing file.", "iLogic")
 I hope this helps.
Curtis
jdkriek
To take it a little further...
Select Case ThisDoc.Document.DocumentType
	Case 12289: MSG = "Unknown Document"
	Case 12290: MSG = "Part Document"
	Case 12291: MSG = "Assembly Document"
	Case 12292: MSG = "Drawing Document"
	Case 12293: MSG = "Design Element"
	Case 12294: MSG = "Presentation Document"
	Case 12295: MSG = "Foreign Model"
	Case 12296: MSG = "SAT File"
End Select
If TypeOf ThisApplication.ActiveEditObject Is Sketch Then
	MsgBox(MSG & " with sketch active")
Else
	MsgBox(MSG)
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
Nice concise code!
