iLogic Pick function
GosponZ
Message 1 of 10
GosponZ
I do have this rule. Pick part in assembly run rule and fill iproperties. Is it there illogic rule that can pick face and then fill iproperties something like in this rule. Thank you
Sub Main()
   Dim oDoc As Document
   oDoc = ThisApplication.ActiveDocument
   Dim comps As SelectSet
   Dim comp As ComponentOccurrence
   comps = oDoc.SelectSet
   'If there are selected components we can do something, otherwise we're done
   If comps.count = 0 Then Exit Sub
   Dim aDoc As DocumentsEnumerator
   aDoc = oDoc.AllReferencedDocuments
   Dim iDoc As Document
   Dim cName As String
   Dim cTS As String
   Dim sTS As String
   Dim FNP As Long
   Dim cFNP As Long
   Dim docFN As String
   For Each iDoc In aDoc
     sTS = iDoc.FullFileName
     FNP = InStrRev(sTS, "\", - 1)
     docFN = Mid(sTS, FNP + 1, Len(sTS) - FNP)
     For Each comp In comps
         cTS = comp.Name
         cFNP = InStrRev(cTS, ":", - 1)
         cName = Left(cTS, cFNP - 1)
         If cName = Left(docFN, Len(docFN)-4) Then
           'Set iProperty in each of the selected parts in assembly
           iProperties.Value(docFN, "Custom", "MATERIAL") = "123"
           iProperties.Value(docFN, "Custom", "MATERIAL DESCRIPTION") = "SOME DESCRIPTION "
     Next
   Next
End Sub
Replies (9)
Message 2 of 10
JaneFan
iLogic has pick funciton to pick with filter:
Dim oFace As Face
oFace = ThisApplication.CommandManager.Pick(selectionfilterenum.kPartFaceFilter, "Select a face")
And with the selected face, we can get the relative Componentdefinition or document which the face belongs to:
oFace.Parent.ComponentDefinition
oFace.Parent.ComponentDefinition.Document
Jane Fan
Inventor/Fusion QA Engineer
Message 3 of 10
GosponZ
Hi Jane,
Thank you for your help.
What i trying to id  is to pick face and based on color of that face fill ipropertie for that face. Could you please guide me little bit more if possible.
Thanks for any input
Message 4 of 10
JaneFan
Hello MisterZS,
The requirement is not clear to me. We can do something according to color of the selected face, but we can't set iProperties to a face since iProperties is part level instead of face or feature level.
Do you want to set the iProperties of the containing occurrence of the selected face?
Jane Fan
Message 5 of 10
GosponZ
Hello Jane,
I do have parts that edge of those have specific color. Based on that color i would like to set custom iproperties for that edge on that part.
Something like if edge color is white then custom edge iprop = abc.
Don't know if that is possible but if you guys programmers experts can help
Thank you
Message 6 of 10
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @GosponZ,
Instead of iPropeties, AttriubteSets might be useful to store data for edges. In the following article, Setting of AttributeSets are discussed.
http://adndevblog.typepad.com/manufacturing/2013/01/inventor-set-attributes-through-api.html
Please feel free to contact if there is any queries,
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 7 of 10
GosponZ
Thank you Chandra for  fast input.
To be honest never worked with attributes.
What i need is e.g. I do have cabinet door. On those 4 edges i  have to put edge band to cover raw edge. That narrow face (3/4") need to have custom ipropertie. One for code we using, and one for description of that code. Those 2 iprops i need to see in drawing.
I'm just looking faster way to fill out iproperties thru iam. in parts.
Thank you
Message 8 of 10
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @GosponZ,
On selecting face, respective ComponentOccurrence will be gathered and iProperties are added to the same ComponentOccurrence. Try the following iLogic code to perform the same.
Sub Main()
    Dim oFace As Face
    oFace = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select a face")
    Dim occ As ComponentOccurrence
    occ = oFace.Parent.Parent
    iProperties.Value(occ.Name, "Custom", "MATERIAL") = "123"
    iProperties.Value(occ.Name,  "Custom", "MATERIAL DESCRIPTION") = "Some description"
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 9 of 10
GosponZ
Thank you Chandra it works perfect.
Message 10 of 10
tomislav.peran
Very nice! Thank you!
Face can be replaced with Edge in the code and than you can select an edge in the same way
