iLogic check the Type of Custom iProperties
douthett
douthett
I'm hoping someone can point me in the right direction for what I'm trying to do
My company has a number of custom iProperties, some of which has different type of Type, ie Boolean, Number...
With the number of users and the number of files my compnay has, it's not unexpected to have one or more of the custom iProperties Type change to Text.  What I want to do is write a code that would check to see if the Type is correct and if not for it alert the user.
And I am stumped.
Balaji_Ram
Here is a code snippet to iterate the custom properties and display its type :
Dim oPartDoc As PartDocument
oPartDoc = ThisApplication.ActiveDocument
Dim invCustomProps As PropertySet
invCustomProps = oPartDoc.PropertySets.Item("User Defined Properties")
Dim oProp As Inventor.Property
For Each oProp In invCustomProps
	If TypeOf oProp.Value Is Integer Then
		MessageBox.Show(oProp.Name & " is Integer type : " & oProp.Value, "iProperty type check")
	Else If TypeOf oProp.Value Is Date Then
		MessageBox.Show(oProp.Name & " is Date type : " & oProp.Value, "iProperty type check")
	Else If TypeOf oProp.Value Is Boolean Then
		MessageBox.Show(oProp.Name & " is YesNo type : " & oProp.Value, "iProperty type check")
Next
Balaji
Balaji
Developer Technical Services
Autodesk Developer Network
douthett
Thanks you for the code.  It's the exact type of signpost I needed.   I can now play with it so it only check iproperties we need check.
douthett
How would you write it if you're check to see if it's text?
douthett
Never mind.  I figure it out.  it was String
