Ilogic - change view label properties
Does anyone know how to change the view label in the base view only!!
I have this code but it adds it to all views.
SyntaxEditor Code Snippet
'start of ilogic code
sString1 = "<Property Document='model' PropertySet='Design Tracking Properties' Property='Description' FormatID='{32853F0F-3444-11D1-9E93-0060B03C1CA6}' PropertyID='29'>DESCRIPTION</Property><StyleOverride Underline='True'>"
sString2 = "<Property Document='model' PropertySet='Design Tracking Properties' Property='Material' FormatID='{32853F0F-3444-11D1-9E93-0060B03C1CA6}' PropertyID='20'>MATERIAL</Property></StyleOverride><StyleOverride Underline='True'> - </StyleOverride><StyleOverride Underline='True'><Property Document='model' PropertySet='User Defined Properties' Property='Thickness' FormatID='{D5CDD505-2E9C-101B-9397-08002B2CF9AE}' PropertyID='6'>Thickness</Property></StyleOverride>"
Dim oDoc As DrawingDocument:  oDoc = ThisDoc.Document
oModel = ThisDoc.ModelDocument
Dim oSheets As Sheets
Dim oSheet As Sheet
Dim oViews As DrawingViews
Dim oView1 As DrawingView
oSheets = oDoc.Sheets
For Each oSheet In oSheets
oViews = oSheet.DrawingViews
    For Each oView1 In oViews
    'make view label visible
   oView1.ShowLabel = True
    oView1.Label.FormattedText = sString1 & "<Br/>" & sString2
    Next
Next
'end of ilogic code
I think it has something to do with oview1.showlabel = true.
ISyntaxEditor Code Snippet
oDrawView.DisplayDefinitionInBase = True
and the above line but I cannot figure it out.
I think this would help you,
Change these lines of your code..
If oView1.ViewType = 10501 Then
' 10501 is a base type (kStandardDrawingViewType) enum
Next
Works great many thanks.
