How to detrmine if a custom level of detail has been saved?
I need to vallidate if a custom level of detail has been saved, any ideas?
perrysc
Saved where? Your workspace? Another employee's workspace? Other?
The assembly document is saved to a location designated by the user, so this could either local or networked. Whilst it is straightforward to find out if the assembly document has been saved, my question relates to whether it is possible to identify if a assembly document has been saved with a specific level of detail. At this stage I have the document in memory.
The application is used to copy an assembly to a new location, renaming the assembly and all its component parts then rebuilding the assembly using the new components. Part of the vallidation process is to ensure that the current level of detail has been saved before committing the transfer.
perrysc
I'd imagine it would be something like this.
Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument 'or other reference to it
Dim oAsmDef As AssemblyComponentDefinition = oAsmDoc.ComponentDefinition
Dim oLODwanted As String 'The name of your LOD you want to be saved as
Dim oHasBeenSaved As Boolean = False
For Each oLOD As LevelOfDetailRepresentation In oAsmDef.RepresentationsManager.LevelOfDetailRepresentations
If oLOD.LevelOfDetail = 56072 AndAlso oLOD.Name = oLODWanted Then 'is kCustomLevelOfDetail and namecheck
oHasBeenSaved = True
MsgBox("This assembly has been saved with " & oLODwanted)
Exit For
Next
If Not oHasBeenSaved Then
MsgBox("This assembly has not been saved with " & oLODwanted)
Exit Sub
Explanation: The level of detail enumerator resides as kSandboxLevelOfDetail until saved, which can be monitored as Perry has indicated. Thanks Perry, good answer. Peter
