Problem with BOM api calls on assembly with Level of detail other than master
DWhiteley
Advisor Advisor
Message 1 of 14
DWhiteley
These calls fail if the assembly LOD representation is set to anything other than MASTER.
' Set the structured view to 'all levels'
oBOM.StructuredViewFirstLevelOnly = False
' Make sure that the structured view is enabled.
oBOM.StructuredViewEnabled = True
'oBOM.PartsOnlyViewEnabled = True
oBOMView = oBOM.BOMViews.Item("Structured")
Inventor 2018.1.2
Is this a known issue?
Dave
Envisage UK Ltd
Replies (13)
Message 2 of 14
pball
I can't say if it's an issue or just designed that way, but I have run into that.
If you need to run this code in a different level of detail I don't know what to say. If you are ok with switching the master to run this code I did the following which prompts the user if they want to switch to master and run or exit.
        Dim oDoc As AssemblyDocument = ThisApplication.ActiveEditDocument
        If (oDoc.ComponentDefinition.RepresentationsManager.ActiveLevelOfDetailRepresentation.Name <> "Master") Then
            If (MsgBox("Master level of detail not selected." & vbNewLine & "Click Yes to switch to Master LOD or No to cancel.", MsgBoxStyle.YesNo) = MsgBoxResult.Yes) Then
                oDoc.ComponentDefinition.RepresentationsManager.LevelOfDetailRepresentations.Item("Master").Activate()
            Else
                Me.Close()
                Exit Sub
Update:
There are other threads on this exact issue. The consensus is that the BOM can only be accessed in the main level of detail. Search up the other threads if you want to read more about it.
Check out my style edits for the Autodesk forums
pball's Autodesk Forum Style
Message 3 of 14
DWhiteley
Nice one! Many thanks
Message 4 of 14
frederic.vandenplas
What i did , is loop through the assembly and set all supressed parts a reference, switch to master and loop the bom, quantities are correct and tv en switch back to lod and revert the reference state, quite a challenge but it Works!
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
Message 5 of 14
jjstr8
I would consider this a bug.  The BOM command from the ribbon bar doesn't seem to care about suppressed parts, so why should the API.
Message 6 of 14
C-Hoppen
Why ist this thread marked as solved???
The problem still exists even in Inventor 2020. If I call the BOM with a user defined LOD, BomRow.ChildRows are always nothing/null. Even when BomView is "Model" (Bom.BOMViews[1])
Is there any useful solution?
Christoph
Message 7 of 14
Perhaps it is a bug or is intentional due to other programming complexities. This code works well to change LOD to master and back to whatever LOD was originally set.  I use this in my BOM export codes and it works great. I have over 18 staff that use the bom export codes that has this embedded in it:
'To Get the ActiveLevelOfDetailRepresentation Name
                        Dim MyLOD_Name As String
                        MyLOD_Name = odef.RepresentationsManager.ActiveLevelOfDetailRepresentation.Name
                        If Not MyLOD_Name = "Master" Then
                        'activate master because only it can enable access to the BOM
                            Call odef.RepresentationsManager.LevelOfDetailRepresentations.Item(1).Activate
'To set your LOD back to original
    odef.RepresentationsManager.LevelOfDetailRepresentations.Item(MyLOD_Name).Activate
Message 8 of 14
pball
@C-Hoppen
Level of Details were designed as memory management tools, not as configuration tools. That is most likely why the BOM cannot be accessed in anything but the main LOD. It wasn't designed that way.
Message 9 of 14
C-Hoppen
Thanks. My intention was not to configure the BOM by LOD. I just wanted to query the BOM regardless what LOD is  activated....
Why can I call the BOM from the UI with any LOD, but the API fails?
Regards
Christoph
Message 10 of 14
I think I understand your wanting to query the BOM. But why can't you use the code to change LOD to Master level while you query and then back once you are done with the query? I know, a work around as usual.
Almost all my macros that I have created are work around for one or another wall that is in place. Its like a maze game with hidden clues.
Message 11 of 14
jjstr8
@pball wrote:
@C-Hoppen
The point being made is that the UI BOM doesn't care what the LOD is set to, so why should the API access?  I agree with what you're saying about the purpose for the LOD, but the BOM is separate from the LOD.
Message 12 of 14
C-Hoppen
That's the point! The UI BOM doesn't care what the LOD is set to. But the API does! Any access to the BOM object fails if the LOD is not set to "Master".
Message 13 of 14
BrianEkins
I don't have any inside knowledge about LOD's and the BOM but have run into this issue myself on a project I'm working on.  One thing that's interesting is that if you open an assembly with a lot of LOD's active and look at the numbers in the lower-right corner of the Inventor window.  The second number is the number of documents currently open.  When I run the BOM command, this number jumps up and when I exit the command it goes back down.
When a part is suppressed that document isn't loaded, but to create a BOM Inventor needs to get information from that document.  Apparently it's opening the document independently of the assembly to get what it needs and then when you close the command it closes the document.  The command is playing these tricks to allow it to work with any LOD.  The API could certainly be enhanced to do something like this but it would need a way to know when you're done so it can close the documents.  I would be a little concerned about a very large assembly with a lot of active LOD's.
Brian Ekins
Message 14 of 14
C-Hoppen
Brian,
I have never noticed that, but it explains everthing.
The command is playing these tricks to allow it to work with any LOD.  The API could certainly be enhanced to do something like this...
Would be great to have the ability to open (all) the documents independently from the LOD. Because its a time difference to open some files or switch to LOD "Master" in huge assemblies.
I could write my own BOM funtion, but calling the BOM is much more faster than reading all iProperties for all occurrences. Why is reading iProperties such slow...?
Regards
Christoph
