Help: Code For "Export face as". Have tried everything i know
xenocatalyst
Message 1 of 28
xenocatalyst
I have been trying to write an iLogic rule to automate the process of exporting a selected face to a dxf file.
The file name and location is set using information from iproperties and project values.
I have searched this forum and the web in general but cant seem to find an answer to my problem.
My background in coding is from autocad lisp (enough to get me by), maybe this is confusing my understanding of iLogic.
Maybe the code i have found is for VB and not iLogic.
With all the examples i have referenced I have been unable to see any link between the select face function and the export function.
How does "GeomToDXFCommand" know what face you have selected?
With the code I have everything seems to work except the actual export function.
When i run the rule from the iLogic Browser (right click, run), i get prompted to select a face.
I select the face i want to export and then nothing.
If I then right click and select "Export Face As" a dxf file with the correct filename is created in the project folder in a folder called "DXF".
This happens without and dialog box or prompts, as I would expect if the ilogic rule ran correctly.
Any help with coding or my understanding of the code would be greatly appreciated.
Here is my code, it is a work in progress so it may be a bit untidy.
I have also attached the ilogic file.
'check that this active document is a part file
'[ ;Part Check
Imports System.Windows.Forms
If ThisApplication.ActiveDocument.DocumentType <> kPartDocumentObject Then
MessageBox.Show ("Please open a part document", "iLogic")
'[ ;Set Variables
oPath = ThisDoc.Path
''Set a reference to the active document (the document to be published).
Dim oDocument As Document = ThisApplication.ActiveDocument
'' Create a DataMedium object
Dim oDataMedium As DataMedium = ThisApplication.TransientObjects.CreateDataMedium
	oQty = iProperties.Value(docFName, "Project", "Stock Number")
	oMat = iProperties.Value(docFName, "Summary", "Comments")
	oFolder = oPath & "\DXF\"
	oFileName = ThisDoc.FileName(False) & " - "& oMat & " - " & oQty & " Required.dxf" 'without extension
''Check for the DXF folder and create it if it does not exist
	If Not System.IO.Directory.Exists(oFolder) Then
    	System.IO.Directory.CreateDirectory(oFolder)
''Set the dxf target file name
oDataMedium.FileName = oFolder & oFilename
DefaultChoice = True
'MessageBox.Show(oDataMedium.FileName)
''copies filename to clipboard for paste (ctrl + v)
'Clipboard.SetText(oFileName)
'[;Selection Code
Dim testFace As Face
                 Try
                 testFace = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select a face")
                 Catch  ex As Exception
                 End Try
                    If (testFace Is Nothing) Then
                        Return
'[;Export code 1
'Get CommandManager object
'Dim Cm As CommandManager
'Cm = ThisApplication.CommandManager
Dim Cm As CommandManager = ThisApplication.CommandManager
Cm.PostPrivateEvent(PrivateEventTypeEnum.kFileNameEvent, oDataMedium.FileName)
'Get control definition for the line command.
'Dim oCDef As ControlDefinition = Cm.ControlDefinitions.Item( "GeomToDXFCommand")
'oCDef.Execute()
'''at this point i can right click on face and select 'Export as face' and it will be saved properly
'''without any further input.
'''Its Almost as if the selected face isn't being parsed to the GeomToDXFCommand.
'[;Clear Variables
oPath = Nothing
oDocument = Nothing
oDataMedium = Nothing
oQty = Nothing
oMat = Nothing
oFolder = Nothing
oFileName = Nothing
testFace = Nothing
Replies (27)
Message 2 of 28
MechMachineMan
Why are these 2 lines commented out in your code?
'oCDef.Execute()
 They are the 2 that actually perform the control definition function.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 3 of 28
xenocatalyst
These were commented out while i was testing, they don't seem to make a difference to the outcome however.
'oCDef.Execute()
Message 4 of 28
xenocatalyst
Through testing I have discovered that the problem does not lie in the export code but in the selection code.
'Selection Code
      Try
      End Try
      Return
While this code indeed allows me to select the appropriate face it doesn't hold onto the the face as a pre-selection.
If i select the face prior to running the ilogic rule it all works fine but i would prefer the selection to be handled within the rule.
Can anyone help me remedy this?
Message 5 of 28
frederic.vandenplas
I guess (without testing) that you need to add the face to a selectset before exporting
This is normal behaviour just as in this post that i solved Face Parallel to display
Without adding it to a selectset, the command "Look at" isn't excuted as expected.
Dim oSelSet As SelectSet
Set oSelSet = oDoc.SelectSet
Dim oFace As Face
Set oFace = ThisApplication.CommandManager.Pick(kPartFacePlanarFilter, "Select a face.")
If oFace Is Nothing Then
Exit Sub
Else
Call oSelSet.Select(oFace)
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
Message 6 of 28
xenocatalyst
Hello Frederic,
Thank you for the answer.
I have included the the code as per your example and it is now working fantastically.
Message 7 of 28
frederic.vandenplas
Glad to here that!
Message 8 of 28
can I have the actually code..i tried to copy and paste and I get error saying 'set' and 'lets' assignment statements are no longer supported..i am no means a programmer.. 🙂
Message 9 of 28
xenocatalyst
Hi jsmanrique
I'm not really a programmer either. I have done qbasic and website production but those skills are 20 year out of date now.
I have had problems with trying bits of code I have found throughout the internet and have found that people don't know or don't tell you if the code is ilogicvb, vba, or vb.net.
The code I'm working in is iLogicvb.
The code frederic.vandenplas posted was vba. (as in macros)
While Frederic's code wasn't exactly correct for ilogic, it gave me the method that I was missing.
Which was adding the face to the selection set. ie: oSelSet.Select(oFace)
I now have my code working in iLogicVB and as a Macro(VBA).
I had to add in the "Let" and "Set" statements for it to work in VBA.
My next step is to create an Inventor Addin. I though If I could get the code to work in VBA that it would be easy to transfer to VB.net.
However I have learnt that VBA is an old revision of visual basic and VB.NET is the current version, and that iLogic is actually closer to VB.net than VBA.
Sorry for the long winded explaination but if I say it here it may help many others.
Here is a working version of my code. I hope it helps.
''Set Variables
Dim oDoc As PartDocument
	oDoc = ThisApplication.ActiveDocument
	oFolder = ThisDoc.Path & "\DXF\"
'add filename to memory for file save dialog
	Cm.PostPrivateEvent(PrivateEventTypeEnum.kFileNameEvent, oFolder & oFilename )
Dim oSelectSet As Selectset
	oSelectSet = oDoc.SelectSet
oDoc.SelectSet.Clear()
'SELECTION CODE
Dim oFace As Face
oFace = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select a face")
If (oFace Is Nothing) Then
Return
Else
Call oDoc.SelectSet.Select(oFace)
' EXPORT CODE 1
Dim oCtrlDef As ButtonDefinition
oCtrlDef = ThisApplication.CommandManager.ControlDefinitions.Item("GeomToDXFCommand")
Call oCtrlDef.Execute
'CLEAR selectset
Message 10 of 28
Thanks so much for the quick reply!! works great, just need to fool around with dxf file name and locations..great job
Message 11 of 28
fabiorcferreira
Can you make it so the file saves as dwg instead of dxw?
Message 12 of 28
ithelpdesk
Hi,     i am trying to automate the process.can any one help me.
1)I have an Assembly file with all parts.
2) Select the part which as description starting "PL". .
3) open the part and select the face export to ".dxf and close
4) if the part is sheet metal then unfold and export face as ".dxf Note: the face which is to be exported may be part file or sheet metal file. kindly help me to solve this.
thanks
Sri
Message 13 of 28
3DAli
Hi ,
this post helped me a lot and I wanted to thank you for that,
I am facing a similar issue when I add a face to my select set not using pick method. I tested my code, my select set is not empty and the face is added , but the export face command does not produce any result. I have a piece of code that automatically identifies the biggest planar face in a part, then I want to export that face and it fails.
when I run it, it runs without any error, and it gives me the confirmation message , but the DXF folder is empty.
any idea as to what could be a work around solution to select a face in any other ways than Pick method?
Regards
Ali
Sub Face_to_dxf(BFace As Face)
Dim oDoc As Document
Set oDoc = ThisApplication.ActiveDocument
Dim oDef As PartComponentDefinition
Set oDef = oDoc.ComponentDefinition
Dim oSelect As SelectSet
Set oSelect = oDoc.SelectSet
Call oSelect.Select(BFace)
oFolder = "C:\DXF\"
oFilename = "Test.dxf" 'without extension
Set Cm = ThisApplication.CommandManager
Call Cm.PostPrivateEvent(PrivateEventTypeEnum.kFileNameEvent, oFolder & oFilename)
 If oSelect.Count > 0 Then
  If oSelect.Item(1).Type = kFaceObject Then
   'Call Save as dxf
   Set oCtrlDef = ThisApplication.CommandManager.ControlDefinitions.Item("GeomToDXFCommand")
   MsgBox "Biggest Face Exported!", vbInformation, "Export to dxf"
   Call oDoc.SelectSet.Clear
   Else
    MsgBox "No area was choosen!", vbCritical, "Export to dxf"
    Exit Sub
End Sub
Message 14 of 28
MechMachineMan
Try reselecting the face (using the variable and oDoc.Select) immediately
before running the command.
Justin K
Message 15 of 28
3DAli
@MechMachineMan
I tried it , unfortunately didn't resolve the issue. I also found this in another post and I don't know how to use it, I am playing around with it as we speak.
"A SelectSet deals with objects selected in the graphics window through user
interaction. If you know the objects you want programmatically, just add
them to a Collection or IV ObjectCollection
(IvApp.TransientObjects.CreateObjectCollection)"
if you know how to use object collection method , can you please post an example.
Cheers
Ali
Message 16 of 28
xenocatalyst
Hi MechMachineMan,
You need to define Bface somehow before you can add it to the selectset.
That is what I used the commandmanager.pick method to do.
Message 17 of 28
3DAli
BFace is defined using the following code, then I call the sub above
Dim oPartDoc As PartDocument
Set oPartDoc = ThisApplication.ActiveDocument
Set oDef = oPartDoc.ComponentDefinition
Dim f As Face
Dim bf As Face
Dim area As Double
  For Each f In oDef.SurfaceBodies(1).Faces
    ' Only care about planar faces
    If TypeOf f.Geometry Is Plane And f.Evaluator.area > area Then
      Set bf = f
      area = f.Evaluator.area
  Next
Message 18 of 28
xenocatalyst
Shouldn't your variable "bf" be "BFace" to match the variable in your sub.
Message 19 of 28
3DAli
not necessarily, you can call the sub like this
Call Face_to_dxf(bf)
, anyways, this is not what causes the issue, the problem is with selection method
Message 20 of 28
xenocatalyst
I just ran this though iLogic and it works well.
I added some code to check if the directory exists and I believe that was the only issue I had.
Here is the code I used
Sub Main()
Dim oPartDoc As PartDocument = ThisApplication.ActiveDocument
Dim oDef As PartComponentDefinition = oPartDoc.ComponentDefinition
Dim f As Face
Dim bf As Face
Dim area As Double
    If TypeOf f.Geometry Is Plane And f.Evaluator.Area > area Then
      bf = f
      area = f.Evaluator.Area
  Next
End Sub
Dim oDoc As Document = ThisApplication.ActiveDocument
Dim oDef As PartComponentDefinition = oDoc.ComponentDefinition
Dim oSelect As SelectSet = oDoc.SelectSet
oFolder = "C:\DXF\"
'[added this check
	   Dim oCtrlDef As ButtonDefinition = ThisApplication.CommandManager.ControlDefinitions.Item("GeomToDXFCommand")
	   MessageBox.Show("Biggest Face Exported!", "Export to dxf")
   Else
    MessageBox.Show("No area was choosen!", "Export to dxf")
    Exit Sub
End Sub
