Announcements
Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Example: Create and Activate Model States in the assembly and subassemblies
7 REPLIES 7
Message 1 of 8
Curtis_Waguespack
4049 Views, 7 Replies
Hi everyone,
I created this iLogic rule to build out a "LOD model state"  in the top level assembly and subassemblies, rather than having to open each file and add the state. I haven't tested it much, but thought I'd share it here.... if you run into issues just post here.
I hope this helps.
Curtis
Update: see next post
7 REPLIES 7
Message 2 of 8
Update to the previous.... it wasn't activating the model state in nested subassemblies
Sub Main
	oName = InputBox("Prompt", "iLogic", "LOD State")
	Dim oDoc As AssemblyDocument
	oDoc = ThisApplication.ActiveDocument
	Dim oAsmCompDef As AssemblyComponentDefinition
	oAsmCompDef = oDoc.ComponentDefinition
	Dim oModelState As ModelState
	'create ModelState in the top level
	Try
		oModelState = oDoc.ComponentDefinition.ModelStates.Add(oName)
		oDoc.ActiveModelState = oName
	Catch
	End Try
	Call TraverseAssembly(oDoc.ComponentDefinition.Occurrences, oName)
	InventorVb.DocumentUpdate()
End Sub
Sub TraverseAssembly(Occurrences As ComponentOccurrences, oName As String)
	Dim oOcc As ComponentOccurrence
    For Each oOcc In Occurrences
		If oOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
			CreateModelState(oOcc, oName)
		    Call TraverseAssembly(oOcc.SubOccurrences, oName)
			'get the parent, if it exists, open it and
			'activate the model states in it
			If oOcc.ParentOccurrence IsNot Nothing Then
				Logger.Info("oOcc: " & oOcc.Name)
				Logger.Info("parent: " & oOcc.ParentOccurrence.Name)
				oParent = oOcc.ParentOccurrence.Definition.Document.fullfilename
				oDoc = ThisApplication.Documents.Open(oParent, False)
				oDoc.ComponentDefinition.ModelStates.item(oName).activate
			 	For Each iOcc In oDoc.ComponentDefinition.Occurrences
					If iOcc.Definition.Document Is oOcc.Definition.Document Then
				 	iOcc.ActiveModelState = oName
					oDoc.Close
				Next
   Next
End Sub
Sub CreateModelState(oOcc As ComponentOccurrence,oName As String )
	oMSFactory = oOcc.Definition.FactoryDocument
	Try
		'try to create new model state
		oModelState = oMSFactory.ComponentDefinition.ModelStates.add(oName)
	Catch
		'catch errors when state already exists, etc
	End Try
	Try
		oOcc.ActiveModelState = oName
	Catch
	End Try
End Sub
Message 3 of 8
Here is another version that allows you to select components and suppress them... might be a little buggy, but seemed to work pretty well.
Sub Main
	oCurrrent = oDoc.ModelStateName
	Dim oList As New ArrayList
	oList.Add("*** Create New State ***")
	For Each oModelState In oDoc.ComponentDefinition.ModelStates
		oList.Add(oModelState.Name)
	Next
	oName = InputListBox("Select one to use", oList, oCurrrent, "iLogic", "List")
	If oName = "*** Create New State ***" Then
		oName = InputBox("Enter name for new model state", "iLogic", oCurrrent)
	If oName = "" Then Return 'exit rule
	oFound = False
	'look for Modelstate and set active if found
		If oModelState.Name = oName Then
			oDoc.ComponentDefinition.ModelStates.Item(oName).Activate()
			oFound = True
	Next
	If oFound = False Then
	While True
		oMsg = "Select components to suppress (press ESC to continue)"
		oOcc = ThisApplication.CommandManager.Pick(
		  SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, oMsg)
		' If nothing gets selected then we're done
		If IsNothing(oOcc) Then Exit While
		'work with first level components
		If oOcc.ParentOccurrence Is Nothing Then
			If oOcc.Suppressed = True Then
				oOcc.Unsuppress
			Else
				oOcc.Suppress
		'work with lower level components
		Else If oOcc.ParentOccurrence IsNot Nothing Then
				oAction = "SetSuppress"
				Call ActivateSub_ModelState(oParent, oName, oAction, oOcc)
	End While
End Sub
			Try
			Catch Ex As  Exception
				'Logger.Info("TraverseAssembly, Exception: " & Ex.Message)
			End Try
					oDoc.Close
				Next
   Next
End Sub
	Logger.Info("CreateModelState, oOcc: " & oOcc.Name)
	Try
	Catch ex As Exception
		'Logger.Info("CreateModelState, ModelStates.add, Exception: " & ex.Message)
	End Try
	Try
		'Logger.Info("CreateModelState, ActiveModelState, Exception: " & ex.Message)
	End Try
End Sub
Sub ActivateSub_ModelState(oParent As String, oName As String, oAction As String, oOcc As ComponentOccurrence)
'	Logger.Info("ActivateSub_ModelState, oOcc: " & oOcc.Name)
'	Logger.Info("oParent: " & oParent)
'	Logger.Info("oName: " & oName)
'	Logger.Info("oAction: " & oAction)
	If oAction = "Activate" Then
				Logger.Info("iOcc name " & iOcc.Name)
			Next
	If oAction = "SetSuppress" Then
		xOcc = oDoc.ComponentDefinition.Occurrences.ItemByName(oOcc.Name)
		Logger.Info("__________ " & xOcc.Name)
		If xOcc.suppressed = True Then
			xOcc.unsuppress
		Else
			xOcc.suppress
	oDoc.Close
End Sub
Message 4 of 8
Thanks...
But have your tried loading some iproperties onto the master state and then go to your custom level and find that all the loaded iproperties are gone?
I then load them onto the custom state and find that master iproperties are gone...
these model states are causing a lot of problems.. specially if you work with derived parts it seems...
Message 5 of 8
Thanks for this snippet, it has sparked  an idea.
Before Model States we would use iLogic to make a "cut-out" in an occurrence, in a sub-assembly, by making the occurrence independent and replacing it with another part.
Thus ensuring that none of the other occurrences in the pattern had a "cut-out".
So our thoughts are that we could use Model States to make the independent "cut-out" without the need for the "replace component" operation...???
Does that make sense and is there a way, using iLogic, to create a Model State in an independent occurrence in a pattern, in an assembly...???
Thanks.  😉
Message 6 of 8
We received some great code here, thanks everyone.  👍
Solved: Create Model States using iLogic - Autodesk Community - Inventor
Message 7 of 8
Hi Curtis
Very useful code!  It seems like something that many people are looking for.
I am trying to use the code in one of my assemblies but the weights in the top level model do not seem to change nor do parts hidden get suppressed in sub-assemblies.  Can you please give a run down on how your code should be used
Message 8 of 8
tecnico
in reply to: Curtis_Waguespack
it is possible to create a similar rule but which allows, within the PART, to create a model state with the same name as the modified parameter (For example, parameter name HEIGHT = 30 MODEL STATUS = 30)
and if it does not exist, create it otherwise activate the already existing one? I think you can also use the way of a list that is updated with each new value.
