Circular patterns feature strange results
I'm trying to create a circular pattern feature using a PartComponentDefinition.Features.CircularPatternFeatures.AddByDefinition() method, and I'm getting unexpected results. The problem lies in the fact that the angle given by me is for some reason not used BUT an angle 229.183118052 is constantly used. I tried to specify an angle using parameters below: "360 deg", convert degrees to radians, but always using the angle 229.183118052. Thanks for any help!
That's what I get (wrong)
That's what i want
UPD: Specifiing the needed angle using CircularPatternFeature.Angle._Value property after building circular pattern is solving my problem, but it seems in the API method there is a bug.
Accepted solutions (3)
AlexFielder
I'd like to add my +1 to this exact error. Using iLogic however means I am unable to use the ._Value fix that was added to the OP.
AlexFielder
Because it might save others (and me, no-doubt) time in the future (at least until Autodesk push out a fix!?) here's my solution that kludges this broken API mechanic and gets the last-created parameter object reassigning its value to the desired parameter:
(NOTE: you will need to add "Imports System.Linq" & "Imports System.Collections.Generic" on separate lines at the top of any iLogic rule you use this within.
It also relies upon a "PatternRotation" parameter whose units are degrees.)
Dim oRotation As String = PatternRotation
	Dim circularPatternDef As CircularPatternFeatureDefinition = oCompDef.Features.CircularPatternFeatures.CreateDefinition(objColl, oCompDef.WorkAxes("Z Axis"), False, 4, "PatternRotation") ' The PatternRotation parameter used here results in the same value as OP no matter what!
	Parameter.UpdateAfterChange = True
	Dim circularPat As CircularPatternFeature = oCompDef.Features.CircularPatternFeatures.AddByDefinition(circularPatternDef)
	circularPat.SetEndOfPart(True) 'move the EOP so things don't KABOOM
	'THIS IS A KLUDGE TO FIX AUTODESK'S BUG AND SHOULDN'T BE NECESSARY!:
	Dim ModelParamList As List(Of ModelParameter) = New List(Of ModelParameter)
	For Each MParameter As ModelParameter In oCompDef.Parameters.ModelParameters
		ModelParamList.Add(MParameter)
	Next
	'debug information
	MessageBox.Show(ModelParamList.Count)
	Dim maxParam As Parameter = Nothing
	Dim maxParamNum As Integer = 0
	If ModelParamList.Count > 0 Then
		ModelParamList.Sort(Function(x As ModelParameter, y As ModelParameter) x.Name.CompareTo(y.Name)) 'would usually use list.OrderBy() extension method here, but iLogic doesn't recognise it!
		maxParam = (From param As ModelParameter In ModelParamList Select param).Last()
	Dim p As ModelParameter = maxParam ' should probably error check this but it works for me!
	p.Expression = "PatternRotation"
	oCompDef.SetEndOfPartToTopOrBottom(False)
I've got the same issue, fixed it for now by doing this:
// Create circular pattern off features
ObjectCollection features = m_inventorApplication.TransientObjects.CreateObjectCollection();
features.Add(*your features to pattern*);
WorkAxis wa = prtDoc.ComponentDefinition.WorkAxes[3]; // Z-Axis
object angle = (360 * 180 / Math.PI);
object amount = 4;
CircularPatternFeatureDefinition cpfd = prtDoc.ComponentDefinition.Features.CircularPatternFeatures.CreateDefinition(features, wa, false, amount, angle, true);
CircularPatternFeature cpf = prtDoc.ComponentDefinition.Features.CircularPatternFeatures.AddByDefinition(cpfd); // ANGLE CIRCULAR PATTERN FIX FOR ERROR IN AUTODESK INVENTOR API, ANGLE NEVER RETURNS CORRECTLY ModelParameter mp = prtDoc.ComponentDefinition.Parameters.ModelParameters[prtDoc.ComponentDefinition.Parameters.ModelParameters.Count]; mp.Expression = "360 deg";
I just changed the last made parameter right after creating the CircularPatternFeature.
dgreatice
try add more line of your code after AddByDefinition :
CirCularPatternFeature.Parameters.item(1).Expression = "360 deg"
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
wesleyosamigos
Community Visitor
Community Visitor
Opa, acredito que a melhor forma é adicionar a operação e posteriormente alterar a propriedade do ângulo
Dim oPatern As CircularPatternFeatureDefinition
Set oPatern = pDef.FlatPattern.Features.CircularPatternFeatures.CreateDefinition(obj, fc, True, Furos, 1)
Dim Pattern As CircularPatternFeature
Set Pattern = pDef.FlatPattern.Features.CircularPatternFeatures.AddByDefinition(oPatern)
Pattern.Definition.Angle.Expression = "360 deg"
Translation:
Hello, I believe the best way is to add the operation and later change the angle property
Traduzido por [@clacampos] através do Google Tradutor
