Change hole type with iLogic
I have an iLogic form to modify some features of a part. See the attached image. I want to program the HoleType drop down to change the hole type from CSink to CBore. I can not figure out how to do this. Can someone show me an example please? Thanks!
Here is the code I have so far. I am getting a parameter is incorrect error. I think the issue is if the original hole is set to CSink then the CboreDepth Parameter does not exist yet. That parameter will only exist if the hole was a CBore. If i set the orinignasl hole to CBore then I have the same issue with ChamferAngle not being a parameter as ChamferAngle is a parameter of the CSink.
Dim partDoc As PartDocument
partDoc = ThisApplication.ActiveDocument
Dim partDef As PartComponentDefinition
partDef = partDoc.ComponentDefinition
Dim hole As HoleFeature
hole = ThisDoc.Document.ComponentDefinition.Features.Item("Hole2")
    If HoleType = "CBore" Then
        hole.SetCBore(ScrewHeadDiameter, CBoreDepth)
	Else If HoleType = "CSink" Then
        hole.SetCSink(ScrewHeadDiameter, ChamferAngle)
	Else If HoleType = "SpotFace" Then
        hole.SetSpotFace(ScrewHeadDiameter, CBoreDepth)
	Else If HoleType = "Drilled" Then
        hole.SetDrilled()
I have also tried replacing the parameter names with actual numbers and I still get the same error.
hole.SetCBore(0.2 in, 0.0625 in)
I figured out my problem. I had to use strings instead of actual numbers.
the documentation says: (See Red Text)
CBoreDiameter Input Variant that defines the diameter of the counterbore. This can be either a numeric value or a string. A parameter for this value will be created and the supplied string or value is assigned to the parameter. If a value is input, the units are centimeters. If a string is input, the units can be specified as part of the string or it will default to the current length units.
The code I'm using that works:
Trigger = HoleType
hole = partDef.Features.Item("Hole2")
        hole.SetCBore("0.2 in", "0.0625 in")
        hole.SetCSink("0.2 in", "82 deg")
        hole.SetSpotFace("0.2 in", "0.0625 in")
        hole.SetDrilled()
