Change Circular Pattern Quantity in sketch symbol
snichols
snichols
Working on some drawing automation and I have the need to change the quantity of a circular pattern in a sketched symbol. I tried the below code with the parameters set in the drawing and it worked for all the dimensions but not the pattern qty.
Option Infer On
Option Explicit On
Dim odoc As DrawingDocument
Dim osymb As SketchedSymbolDefinition
Dim osheet As Sheet
Dim oparam As Parameter
Dim UnderscorePos As Integer
Dim Paramname As String
Dim Dimensionname As String
Dim otitle As TitleBlockDefinition
odoc = ThisDoc.Document
ThisApplication.ScreenUpdating = False
Try
For Each oparam In odoc.Parameters
    'Find the position of the underscore to get the parameter name and the name of the corresponding dimension
    UnderscorePos = InStr(oparam.Name, "_")
    'if no underscore go to next parameter
    If UnderscorePos = 0 Then
        Continue For
    Paramname = Left(oparam.Name, UnderscorePos - 1)
    Dimensionname = Right(oparam.Name, Len(oparam.Name) - UnderscorePos)
    For Each osymb In odoc.SketchedSymbolDefinitions
        Dim oSketch As DrawingSketch
        If Paramname = osymb.Name Then
            Call osymb.Edit(oSketch)
            For Each constraintX In oSketch.DimensionConstraints
                Dim paramX = constraintX.Parameter
                If (paramX.Name = Dimensionname) Then
                    paramX._Value = oparam._Value ' Update the dimension in the sketched symbol with the parameter value
            Next
            osymb.ExitEdit (True)
            'reedit the symbol or title to ensure the change did not corrupt the sketch
    Next osymb
    For Each otitle In odoc.TitleBlockDefinitions
        If Paramname = otitle.Name Then
            Call otitle.Edit(oSketch)
            Next
            otitle.ExitEdit (True)
    Next otitle
Next oparam
Catch
    'in case of error when editing one of the sketch
    Call ThisApplication.TransactionManager.UndoTransaction
    ThisApplication.ScreenUpdating = True
    MsgBox (Paramname & " could not be changed")
Finally
    ThisApplication.ActiveView.Update()
End Try
So I tried doing it with the command manager with the below code. It works somewhat but seems temper-mental.
Imports System.Windows.Forms
    ' Get the CommandManager object.
    Dim oCommandMgr As CommandManager
    oCommandMgr = ThisApplication.CommandManager
    ' Get control definition for the line command.
    Dim oControlDef As ControlDefinition
    oControlDef = oCommandMgr.ControlDefinitions.Item("SketchPatternEditCtxWrapperCmd")
    ' Execute the command.'    Call oControlDef.Execute
    Call oControlDef.Execute2(False)
'    opens To Custom tab ( send "right arrow" key 4 times)
    SendKeys.Sendwait("{TAB 2}")
    SendKeys.Sendwait("{9}")
'    SendKeys.Sendwait("{6}")'    ThisApplication.UserInterfaceManager.DoEvents()'    SendKeys.Sendwait("{TAB 4}")
oControlDef = oCommandMgr.ControlDefinitions.Item("AppContextual_OKCmd")
This is what the sketch symbol looks like, just a pattern of the circles:
 Has anybody found a way to update the pattern qty in a sketch symbol?
Thanks in advance for any help.
snichols
These are the parameters for the first batch of code, sorry I forgot them in the original post.
