Adding Parameters with iLogic
Message 1 of 14
Happy hump day everyone!
my question for today: I am migrating my files from Inventor 2016 to 2017 and would like to add parameters to my existing files without actually adding parameters by opening the parameters dialog and typing them in. Can I do this task via iLogic?
I would like to add following parameters + values
Costlb  (ul)   (Multi value list: 0.65, 1.65, 2.05 + allow custom values)
Material  (text)  (Multi value list)
By   (text)   FJNII
Company   (text)  Company Name
Any and all help appreciated.
Frank
Inventor 2017
Replies (13)
Message 2 of 14
ekinsb
Below is some code you can put in an iLogic rule.  I would recommend an external rule since it's not document specific.  The first variable defines a folder that you want to process.  This will process all of the part files in that folder and any subfolders.  By editing the code you can change the contents of the lists.
Dim pathToProcess As String = "C:\Temp\Files\"
Dim files() As String = System.IO.Directory.GetFiles(pathToProcess, "*.ipt", IO.SearchOption.AllDirectories)
Dim cnt As Integer = 0
For Each file As String In files
	cnt += 1
	ThisApplication.StatusBarText = "Processing file " & cnt & " of " & files.Length & "..."
	Dim doc As PartDocument
	doc = ThisApplication.Documents.Open(file, False)
	' Add the parameters.
	Dim userParams As UserParameters
	userParams = doc.ComponentDefinition.Parameters.UserParameters
	Dim param As UserParameter = userParams.AddByValue("Costlb", 0, "ul")
	Dim values(2) As String
	values(0) = "0.65 ul"
	values(1) = "1.65 ul"
	values(2) = "2.05 ul"
	Dim expList As ExpressionList = param.ExpressionList
	expList.SetExpressionList(values, True, 0)
	param = userParams.AddByValue("Material", "", "Text")
	ReDim values(3)
	values(0) = """Steel"""
	values(1) = """Bubble Gum"""
	values(2) = """Potato Salad"""
	values(3) = """Titanium"""
	expList = param.ExpressionList
	param = userParams.AddByValue("By", "FJNII", "Text")
	param = userParams.AddByValue("Company", "Company Name", "Text")
	doc.Save()
	doc.Close()
Next
Brian Ekins
Mod the Machine blog
Message 3 of 14
Brian,
Tried to run this rule from inside a file and got following error:
Error in rule: Add Parameters, in document: IN-049.ipt
Value cannot be null.
Parameter name: path
Do I need to make a form for this rule? Reading the first line of this rule makes me think this was written to process a complete folder?
Hope you had a great weekend. Thanks for your help.
Frank
Message 4 of 14
ekinsb
It does process all of the part files in the directory specified by the pathToProcess variable.  Did you set that to a valid directory?  There might also be a problem with it if those parameters already exist in the file.  I didn't add any checks for that because I assumed that they wouldn't.
Brian Ekins
Message 5 of 14
Brian,
 I saw that after I posted the last question. So I put in the path and it still threw an error. Not sure how to run a rule outside of a file, so I was running it from an open part file. (not empty) I did save it as an external rule. Was also running it from the same directory I wanted to add the parameters to. Will try other options when I get a chance. Thanks again for your help.
Frank
Message 6 of 14
ekinsb
iLogic is always the best tool for automating Inventor and in many cases, even when it is you'll still be able to prototype code easier and faster in VBA or Visual Studio.  What you're trying to do is a case where I don't think iLogic is the best choice.  Here's a version of the same thing in VBA.  This will also process a directory of part files, but this version won't handle sub-directories.  I also added a check to handle if the file already has the parameters.  The previous version still worked but you would end up with multiple parameters with numbers appended to the names to make them unique.
Public Sub AddProperties()
    pathToProcess = "C:\Temp\Files\"
    Dim fileName As String
    fileName = Dir(pathToProcess & "*.ipt", vbNormal)
    Do While fileName <> ""
        ThisApplication.StatusBarText = "Processing file: " & fileName & "..."
        Set doc = ThisApplication.Documents.Open(pathToProcess & fileName, False)
        ' Add the parameters, if they don't already exist.
        Set userParams = doc.ComponentDefinition.Parameters.UserParameters
        ' Check for the existence of the parameter "Costlb" and exit the program
        ' if it does exist. It's assuming they all exist if "Costlb" is there.
        On Error Resume Next
        Set param = userParams.Item("Costlb")
        If Err.Number = 0 Then
            MsgBox "The parameters already exist.  Exiting the program."
            Return
        On Error GoTo 0
        Set param = userParams.AddByValue("Costlb", 0, "ul")
        Dim values() As String
        ReDim values(2) As String
        Set expList = param.ExpressionList
        Call expList.SetExpressionList(values, True, 0)
        Set param = userParams.AddByValue("Material", "", "Text")
        ReDim values(3)
        Set param = userParams.AddByValue("By", "FJNII", "Text")
        Set param = userParams.AddByValue("Company", "Company Name", "Text")
        Call doc.Save
        Call doc.Close
        fileName = Dir()
    Loop
    ThisApplication.StatusBarText = "Finished."
End Sub
Brian Ekins
Message 7 of 14
Brian,
    You're probably right if I was fluent or even experienced in VBA or Visual Studio. But alas, I'm not, no experience with either or VB.Net. I've managed to pick up enough iLogic to get myself in trouble. As far as this piece of code (Thank you) How do I use it to process a folder/directory to get my parameters into existing part files? Can I do it with a "Custom Task" from the Inventor Task Scheduler?
  While I really appreciate all your help, assume I know nothing ( which is almost true) so I would need step by step instructions on how to best use the help you are providing. Other wise I'm just poking and hoping. Thanks again.
Frank
Message 8 of 14
And thanks for your continued patience.
Frank
Message 9 of 14
ekinsb
I can't edit my most recent post but I assume you understood that I really meant that "iLogic is NOT always the best tool".
Here's a posting on how to use a VBA script.
http://modthemachine.typepad.com/my_weblog/2010/05/using-vba-sample-code-for-the-non-programmer.html
And I hate to break it to you, but you are already programming if you're using iLogic, so it's not a big leap to use some of these other tools. 🙂
Brian Ekins
Message 10 of 14
Brian,
  Thank you for all your help. I'm finally making some headway! Missed a few things along the way but have been figuring them out. Had to edit the value (3) for the material list, had me stumped for a bit, but figured it out. Also missed the edit for my company name, that was easy. Got another question for you. On the multi value list for my materials (we don't make anything out of potato salad BTW) how do I "allow custom values"? Otherwise I'm good to go for now. Thanks again for you patience and help.
Frank
Message 11 of 14
ekinsb
Hi Frank,
Unfortunately, it looks like that setting is missing from the API.  I think it was added later after the initial implementation of lists and has been overlooked. I can't think of any kind of work around.  The best thing to do would be to post it on the Idea Station with API as a tag.  It's certainly a reasonable request.
Brian Ekins
Message 12 of 14
DRoam
For anyone who would like to vote, here is @Anonymous's suggestion in the IdeaStation: IdeaStation: API Improvement
Message 13 of 14
Hello Frank,
I posted this on the Idea Station too (Idea) , but if someone wouldn't hit it: the option you're looking for, is available:
as soon as the parameter has an ExpressionList, inventor saves an attribute to it, which controls this.
HTH!
BR,
Daniel
Message 14 of 14
I'm wondering if there is a separate idea station for Inventor API... a had a few... Smiley Happy
BR,
Daniel
