Adding Model Annotations (ModelLeaderNotes) works in Part, but fails in Assembly
josh.nieman
josh.nieman
I've used the code samples shown here: http://adndevblog.typepad.com/manufacturing/2018/03/adding-modelfeaturecontrolframe-in-partdocument-...
and gotten them to work in the part environment.  I'm trying to now adapt this code to work in an assembly, and running into confusing errors.  Well... confusing to me (I'm pretty new to this)
I get the following error at the line in red below:
System.Runtime.InteropServices.COMException: 'The remote procedure call failed. (Exception from HRESULT: 0x800706BE)'
What is causing this?  I can't seem to find the root cause.
Private Sub TEST_Click(sender As Object, e As EventArgs) Handles TEST.Click
Dim Doc As Document
Dim oDef As AssemblyComponentDefinition
Dim oTG As TransientGeometry
Dim dViewRepMgr As RepresentationsManager
Dim dWeldView As DesignViewRepresentations
InvApp = Marshal.GetActiveObject("Inventor.Application")
Doc = InvApp.ActiveDocument
oDef = Doc.ComponentDefinition
oTG = InvApp.TransientGeometry
dViewRepMgr = oDef.RepresentationsManager
dWeldView = dViewRepMgr.DesignViewRepresentations
Dim oFace As Face
oFace = InvApp.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select a face to attach leader")
Dim oAnnoPlaneDef As AnnotationPlaneDefinition
oAnnoPlaneDef = oDef.ModelAnnotations.CreateAnnotationPlaneDefinitionUsingPlane(oFace)
Dim oLeaderPoints As ObjectCollection
oLeaderPoints = InvApp.TransientObjects.CreateObjectCollection
oLeaderPoints.Add(oTG.CreatePoint(5, 10, 0))
Dim oLeaderIntent As GeometryIntent
oLeaderIntent = oDef.CreateGeometryIntent(oFace)
oLeaderPoints.Add(oLeaderIntent)
Dim oLeaderDef As ModelLeaderNoteDefinition
oLeaderDef = oDef.ModelAnnotations.ModelLeaderNotes.CreateDefinition(oLeaderPoints, "Finally it works", oAnnoPlaneDef)
Dim oLeader As ModelLeaderNote
oLeader = oDef.ModelAnnotations.ModelLeaderNotes.Add(oLeaderDef)
End Sub
clutsa
It doesn't look like assembly documents support ModelFeatureControlFrames yet. Can you do what you're trying to do manually? When I try I don't see the Geometric Annotation
If I've helped you, please help me by supporting this idea.
Mass Override for Each Model State
Custom Glyph Icon for iMates
josh.nieman
That's correct.  I think assemblies SHOULD support FCFs but that's a discussion for another day 🙂
Right now I'm trying to add a LEADER TEXT object (ModelLeaderNotes object)
But the method should be quite similar to how you add a FCF to a part model, I would think.  So I was starting with those samples, as I haven't found samples of anyone adding Model Annotations in an assembly yet.  I'd welcome any of those, as well.
clutsa
try oFace.Geometry on the line that's crashing.
This is what I did in VBA and it works (after several crashes)
Private Sub TEST()
Dim Doc As Document
Set InvApp = ThisApplication 'Marshal.GetActiveObject("Inventor.Application")
Set Doc = InvApp.ActiveDocument
Set oDef = Doc.ComponentDefinition
Set oTG = InvApp.TransientGeometry
Set dViewRepMgr = oDef.RepresentationsManager
Set dWeldView = dViewRepMgr.DesignViewRepresentations
Dim oFace As Face
Set oFace = InvApp.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select a face to attach leader")
Set oAnnoPlaneDef = oDef.ModelAnnotations.CreateAnnotationPlaneDefinitionUsingPlane(oFace.Geometry) 'this line was crashing Inventor
'Set oAnnoPlaneDef = oDef.ModelAnnotations.Item(1).Definition.AnnotationPlaneDefinition 'used the planeDef from an existing annotation for test
Set oLeaderPoints = InvApp.TransientObjects.CreateObjectCollection
Call oLeaderPoints.Add(oTG.CreatePoint(5, 10, 0))
Set oLeaderIntent = oDef.CreateGeometryIntent(oFace)
Call oLeaderPoints.Add(oLeaderIntent)
Set oLeaderDef = oDef.ModelAnnotations.ModelLeaderNotes.CreateDefinition(oLeaderPoints, "Finally it works", oAnnoPlaneDef)
Set oLeader = oDef.ModelAnnotations.ModelLeaderNotes.Add(oLeaderDef)
End Sub
josh.nieman
That absolutely did it...  I appreciate your solution.
I'm not sure why it was necessary in this assembly, but not in a part file, but I'm perfectly happy simply remembering to try the properties of these objects in the future, should I run into something similar.
Thanks!
clutsa
My best guess is in the part the oFace is a "Face" but in the assy oFace is actually a "FaceProxy" and they aren't being handled the same... That's totally me guessing though.
