about SetPromptResultText ()
zhikaobi1725
zhikaobi1725
I am  a new in  inventor  API : Now, I have a question to ask . thanks for lots first
 I use one code  downloaded form this forum to learn . as following
 when the code run to  oTitleBlock.SetPromptResultText (oTextBox,"HELLO WORLD!!!")   a  error   happens
 showing"Conpile error: syntax error"
I downloaded orthers code with the funtion  SetPromptResultText() ,a  same question happens
My  inventor ver. is < inventor  professional 2015>,  Could  any  specilist   tell me? WHY?
Sub title()
 Dim oSheet As Sheet
 Dim oTitleBlock As TitleBlock
 Dim oTextBox As TextBox
 Dim oTextBoxes As TextBoxes
 Set oSheet = ThisApplication.ActiveDocument.ActiveSheet
 If oSheet.TitleBlock Is Nothing Then Exit Sub
 Set oTitleBlock = oSheet.TitleBlock
 If oTitleBlock.Definition.Sketch.TextBoxes Is Nothing Then Exit Sub
 Set oTextBoxes = oTitleBlock.Definition.Sketch.TextBoxes
 For Each oTextBox In oTextBoxes
  If oTextBox.Text = "MYPROMPTEDTEXT" Then Exit For
 If oTextBox Is Nothing Or oTextBox.Text <> "MYPROMPTEDTEXT" Then
 Next
End Sub
JaneFan
Hey @zhikaobi1725,
Thank you for your reporting. This seems an API issue to me. I will get it logged in our internal system.
Jane Fan
Inventor/Fusion QA Engineer
zhikaobi1725
Dear JaneFan:
 Thank you for your answer about this question at first time
Let me know when you have a correct solution.
JaneFan
Hey @zhikaobi1725,
Sorry for misleading. SetPromptResultText  can only be used on the TextBox whose format meets some certain format. Please add following judgment to your code:
 If InStr(1, oTextBox.FormattedText, "<Prompt ") = 1 Then
    Call oTitleBlock.SetPromptResultText(oTextBox, "test")
Jane Fan
