Change Text Syle with Styles Editor
What I'm looking to do is to get my View and Scale to look like this, but I want it as a template so that I don't have to go in and change every one, every time:
So, I go into the Styles Editor and create a new style.
I click on the pencil button, and change each type to how I'd like it to look.
I have also changed the Label Text and Note Text. I have also gone to Object Defaults and made sure that it is pulling my Label Text.
I am getting this once it's all said and done.
And this is because in the object defaults, the View/Scale label are grouped as one item, and both pull Label Text (ANSI).
Is there a way to separate this and create a template where my text looks like the first picture?
YuhanZhang
You can try to save it as a Sheet Format, which is a template for sheet.
1. Right click on the sheet and choose the Create Sheet Format button.
2. Specify a name for it.
3.  Then in the Drawing Resources->Sheet Formats double click the new saved sheet format, and choose a model document to create drawing view.
Now check it if this satisfies your requirement.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
