謝謝提供的方法;我沒說清楚;舉例:我在機台上面配置一個顯示螢幕;位置和機台鎖付固定;我要顯示螢幕複製到一個新開組合件(iam)貼上;而位置點須和原機台上所付的位置相同,類似autocad的功能 剪貼簿 複製 貼上選項 貼到原始座標
这个好像没有现成的操作方法,实现起来比较麻烦,使用ilogic编写规则代码或许可行。
多问一句:你这个需求的最终意图是什么呢?
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
如果我的回帖解决了您的问题,请点击 "接受为解决方案" 按钮. 这可以帮助其他人更快的找到解决方案!
王 承之
Autodesk AGN [Inventor 俱乐部] Leader
Inventor Club | Bilibili
@pointed_idea 可以考虑用ilogic添加新的右键菜单来实现这个功能(设置外部规则自动运行,打开部件或者其他触发条件)
可以复制1个或者同时复制多个(但不会保留约束)
Class ThisRule
Private button_CopyOcc, button_PasteOcc As ButtonDefinition
Dim keyValuePairs As New List(Of KeyValuePair(Of String, Matrix))
Sub main
If SharedVariable.Exists("ContextMenu") Then Return
SharedVariable("ContextMenu") = "ContextMenu"
addNewButton()
AddHandler ThisApplication.CommandManager.UserInputEvents.OnContextMenu, AddressOf OnContextMenu
End Sub
Sub addNewButton()
button_CopyOcc = ThisApplication.CommandManager.ControlDefinitions.AddButtonDefinition(
"复制(原始位置)","IneternalName_copyocc", CommandTypesEnum.kNonShapeEditCmdType)
button_PasteOcc = ThisApplication.CommandManager.ControlDefinitions.AddButtonDefinition(
"粘贴(原始位置)","IneternalName_pasteocc", CommandTypesEnum.kShapeEditCmdType)
AddHandler button_CopyOcc.OnExecute, AddressOf CopyOcc_OnCLick
AddHandler button_PasteOcc.OnExecute, AddressOf PasteOcc_OnCLick
End Sub
Private Sub OnContextMenu(SelectionDevice As SelectionDeviceEnum, AdditionalInfo As NameValueMap, CommandBar As CommandBar)
If Not TypeOf ThisApplication.ActiveEditDocument Is AssemblyDocument Then Return
Dim oselectset As SelectSet = ThisApplication.ActiveDocument.selectset
If oselectset.OfType(Of ComponentOccurrence).Count <> 0 Then
CommandBar.Controls.AddButton(button_CopyOcc, 2)
Else If oselectset.Count = 0 Then
If SelectionDevice <> SelectionDeviceEnum.kGraphicsWindowSelection Then Return
If keyValuePairs.count = 0 Then Return
CommandBar.Controls.AddButton(button_PasteOcc, 2)
End If
End Sub
Private Sub CopyOcc_OnCLick
For Each occ As ComponentOccurrence In oselectset.OfType(Of ComponentOccurrence)
Dim occDocumentName As String = occ.Definition.Document.FullDocumentName
Dim position As Matrix = occ.Transformation
keyValuePairs.Add(New KeyValuePair(Of String, Matrix)(occDocumentName, position))
Next
End Sub
Private Sub PasteOcc_OnCLick
Dim asmDef As AssemblyComponentDefinition = ThisApplication.ActiveEditDocument.ComponentDefinition
For Each kvp In keyValuePairs
Dim key As String = kvp.Key
Dim value As Matrix = kvp.Value
asmDef.Occurrences.Add(key,value)
Next
keyValuePairs.clear()
End Sub
End Class
这个好,学习一下
王 承之
