网上找到的一段将Inventor BOM表分类导出Excel的iLogic代码,在运行规则前,确认BOM表启用了"仅零件"的BOM表视图。iLogic代码如下:
Option Explicit On
AddReference "microsoft.office.interop.excel.dll"
Imports XL = Microsoft.Office.Interop.Excel
Class BOMExport
'将字符串修改为对应的语言版本
Private Const sBOMStructureType As String = "BOM 表结构" 'BOM 表结构列字段名称
Private Const sNormal As String = "普通件"
Private Const sPurchased As String = "外购件"
Private Const sInseparable As String = "不可拆分件"
Private Const sPath As String = "C:\Temp\" 'BOM 导出路径
Private Const sFilename As String = "仅零件_" '文件名的静态部分
Private Sub Main()
'宏:
'- 装配打开中
'- 仅零件视图中不排除“零件类型”列
Dim oApp As Inventor.Application = ThisApplication
Dim oAssdoc As AssemblyDocument = oApp.ActiveDocument
Dim oBOM As BOM = oAssdoc.ComponentDefinition.BOM
Dim oBOMview As BOMView
Dim oExcelApp As XL.Application = GetObject("", "Excel.Application")
If oExcelApp Is Nothing Then
MsgBox ("无法获取 Excel")
Exit Sub
oBOM.PartsOnlyViewEnabled = True
For Each oBOMview In oBOM.BOMViews
If oBOMview.ViewType = kPartsOnlyBOMViewType Then
Exit For
Next
If oBOMview Is Nothing Then
MsgBox ("无法获取BOM仅零件视图")
Exit Sub
If Dir(sPath & sFilename & sNormal & ".xls") <> "" Then
Call MsgBox("文件 " & sPath & sFilename & sNormal & ".xls 已存在.", vbCritical, "导出BOM")
oExcelApp.Quit
Exit Sub
ElseIf Dir(sPath & sFilename & sPurchased & ".xls") <> "" Then
oExcelApp.Quit
Exit Sub
ElseIf Dir(sPath & sFilename & sInseparable & ".xls") <> "" Then
oExcelApp.Quit
Exit Sub
Call oBOMview.Export(sPath & sFilename & sNormal & ".xls", kMicrosoftExcelFormat, sNormal)
Call oBOMview.Export(sPath & sFilename & sPurchased & ".xls", kMicrosoftExcelFormat, sPurchased)
Call oBOMview.Export(sPath & sFilename & sInseparable & ".xls", kMicrosoftExcelFormat, sInseparable)
Dim oWB As xl.Workbook = oExcelApp.Workbooks.Open(sPath & sFilename & sNormal & ".xls")
If Not oWB Is Nothing Then
oWB = Filter(oExcelApp, oWB, sNormal)
oWB.Save
Dim oWB2 As xl.Workbook = oExcelApp.Workbooks.Open(sPath & sFilename & sPurchased & ".xls")
If Not oWB2 Is Nothing Then
oWB2 = Filter(oExcelApp, oWB2, sPurchased)
oWB2.Save
Dim oWB3 As xl.Workbook = oExcelApp.Workbooks.Open(sPath & sFilename & sInseparable & ".xls")
If Not oWB3 Is Nothing Then
oWB3 = Filter(oExcelApp, oWB3, sInseparable)
oWB3.Save
Dim Result As MsgBoxResult
Result = MsgBox("导出完成. 是否查看excel?", vbYesNo, "导出BOM")
If Result = vbYes Then
oExcelApp.Visible = True
Else
For Each oWB In oExcelApp.Workbooks
oWB.Close (False)
Next
oExcelApp.Quit
End Sub
Private Function Filter(ByVal oExcelApp As xl.Application , ByVal oWB As xl.Workbook, ByVal sName As String) As xl.Workbook
Dim oRange As xl.Range
Dim lLastRow As Long
Dim t As Long
oRange=oExcelApp.Cells(oWB.ActiveSheet.Rows.Count, 1)
lLastRow = oRange.End(xl.XlDirection.xlUp ).Rows.Row
Dim s As Long
s = FindColumn(oExcelApp, oWB)
If s = 0 Then
Call MsgBox("未找到BOM表结构列.", vbCritical, "导出BOM")
Filter = Nothing
Exit Function
For t = lLastRow To 2 Step -1
If Not oExcelApp.Cells(t, s).Value = sName Then
Call oWB.ActiveSheet.Rows(t).Delete( Shift:=xl.XlDirection.xlUp)
Next t
Return oWB
End Function
Private Function FindColumn(ByVal oExcelApp As xl.Application , ByVal oWB As xl.Workbook) As Long
Dim lLastColumn As Long
oRange=oExcelApp.Cells(1, oWB.ActiveSheet.Columns.Count)
lLastColumn = oRange.End(xl.XlDirection.xlToLeft).Columns.Column
Dim s As Long
Dim rCells As xl.Range
For s = lLastColumn To 1 Step -1
rCells = oExcelApp.Cells(1, s)
If rCells.Value = sBOMStructureType Then
Return s
Exit For
Next s
End Function
End Class
已解决! 转到解答。
由 lynn_zhang 解答. 转到解答。
陈总也在 “Inventor俱乐部” QQ群?
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
如果我的回帖解决了您的问题,请点击 "接受为解决方案" 按钮. 这可以帮助其他人更快的找到解决方案!
王 承之
Autodesk AGN [Inventor 俱乐部] Leader
Inventor Club | Bilibili
