'Sub Main() 'Programming by DWJ 2021.11.23 China Tianchang city (V4.1). Thanks for Autodesk Rocky and Jane to give me very important help!Just for best inventor ! QQ二次发开交流群:951736200 'oDoc = ThisApplication.ActiveDocument 'Dim sure = MsgBox("确定继续?", vbYesNo, "Autodesk Inventor ilogic") 'If sure = vbYes Then ' Call contencentersavefx(oDoc) ' On Error Resume Next ' oDoc.Rebuild() ' oDoc.save ' Err.Clear ' MsgBox("All done!", , "contencenter零件保存本地") ' Return 'Else ' Return 'End If 'End Sub 'Sub contencentersavefx(ByVal ooDoc) ' Dim osubdoc As Document ' For Each osubdoc In ooDoc.AllReferencedDocuments ' On Error Resume Next ' Dim oName = ThisDoc.Document.FullFileName '例子: C:\Temp\Test\1234.ipt 总装全路径名称 ' Dim oPath = IO.Path.GetDirectoryName(oName) '得到的路径 (returns: C:\Temp\Test) 总装文件夹路径名称 ' Dim osubdocName = osubdoc.FullFileName '例子: C:\Temp\Test\1234.ipt ' Dim oFileName = IO.Path.GetFileName(osubdocName) '获取扩展名的名称 (returns: 1234.ipt) ' Dim newpath = oPath + "\" + oFileName '新路径名(保存总装路径下) ' Dim oIsContentMember = osubdoc.ComponentDefinition.IsContentMember() ' If oIsContentMember = True Then ' ' My.Computer.FileSystem.DeleteFile(newpath, FileIO.UIOption.OnlyErrorDialogs, FileIO.RecycleOption.SendToRecycleBin, FileIO.UICancelOption.DoNothing) ' MsgBox(newpath) ' osubdoc.SaveAs(newpath, False) ' End If ' Err.Clear ' Next 'End Sub Sub Main() oDoc = ThisApplication.ActiveDocument Dim sure = MsgBox("确定继续?", vbYesNo, "Autodesk Inventor ilogic") If sure = vbYes Then Call contencentersavefx(oDoc.ComponentDefinition) oDoc.Rebuild() oDoc.save MsgBox("All done!", , "contencenter零件保存本地") Return Else Return End If End Sub Sub contencentersavefx(ByVal ooDoc As ComponentDefinition) On Error Resume Next Dim oPrds = ooDoc.Occurrences If oPrds.Count>0 Then Dim prdl As ComponentOccurrence For N = 1 To oPrds.Count Step 1 prdl = oPrds.Item(N) Dim ocdoc = prdl.Definition.Document Dim oName = ThisDoc.Document.FullFileName '例子: C:\Temp\Test\1234.ipt Dim oPath = IO.Path.GetDirectoryName(oName) '得到的路径 (returns: C:\Temp\Test) Dim osubdocName = ocdoc.FullFileName '例子: C:\Temp\Test\1234.ipt Dim oFileName = IO.Path.GetFileName(osubdocName) '获取扩展名的名称 ( returns: 1234.ipt) Dim newpath = oPath + "\" + oFileName Dim oIsContentMember = ocdoc.ComponentDefinition.IsContentMember() If oIsContentMember = True Then prdl.Replace(newpath, True) ' MsgBox(newpath) ocdoc.SaveAs(newpath, False) End If If prdl.SubOccurrences.Count > 0 Then Call contencentersavefx(prdl.Definition) End If Next End If End Sub
看来文件后才明白您的意图。
建议您将第一个帖子的格式编辑一下,或直接上程序的截图。 这样看起来更清晰。
