I bought a new computer, Lenovo 910 YOGA, Intel i7-7500U 2.7G, RAM 16G
Why It can't run Both Autocad and Revit?
Can someone give me a help?
Thanks.
Specs.
Processor Speed: | 2.7GHz (Turbo Boost to 3.5GHz) | Product Line: | Lenovo |
Memory: | 16GB | Type: | Notebook/Laptop |
Storage Type: | SSD (Solid State Drive) | Model: | Yoga 910 |
Color: | Silver | Operating System: | Windows 10 Pro |
SSD Capacity: | 1TB | Operating System Edition: | Professional |
Release Year: | 2017 |
Solved by pendean. Go to Solution.
Solved by Alfred.NESWADBA. Go to Solution.
Which version of Revit, which version of AutoCAD and what happens when you start any of them ...?
Also the version of Windows might be interesting.
- alfred -
>> I was wondering that maybe the Autocad 2012 is too old to run
AutoCAD 2016 was the first release for Window 10
I would go back to Windows 7 or run AutoCAD in a virtual system (Oracle VirtualBox, or VmWare), you might have luck if you mark the acad.exe to run in compatibility mode, but even then ... that is not a stable environment.
>> so I downloaded the trail version of Autocad 2018. It's even worse,
>> it couldn't even finish the installation
Again ... we need to know what you see, I'm sure you have got a warning or error message or at least a log-file. As we are not sitting in front of your system we need to get that info's forwarded.
A general option in case of installation troubles (often because the installation was done by the internet-installer) is to download the software from Autodesk Virtual Agent >>>click<<< and when the download is finished then login as administrator, turn off antivirus, start the installer-exe with a right-click and "start as administrator"
But before you install 2018 make sure the old versions of Revit and AutoCAD are uninstalled (and cleaned from the system >>>click<<<)
Good luck, - alfred -
AutoCAD might not run on a Lenovo Yoga 910 due to several potential issues related to hardware compatibility, system requirements, or software conflicts. If you continue to experience issues, providing specific error messages or symptoms can help narrow down the problem further.
