Installation & Licensing
VLIDE in AutoCAD 2024 - I cannot install
5 REPLIES 5
ladimirabdala
477 Views, 5 Replies
Hi guys,
I installed AutoCAD 2024 but I cannot install the VLIDE until now.
I tried search in my VS 2019 the extensions called "autocad autolisp" but the VS can't locate anything.
Could anyone tell me the best way ti access the LISP IDE in AutoCAD 2024?
Thanks in advance.
Ladimir Abdala
Brazil
Tags (1)
5 REPLIES 5
pendean
in reply to: ladimirabdala
@ladimirabdala Simply typing VLIDE in AutOCAD2024 activates it just fine for me, I use it just fine
OR are you using the LT version of AutoCAD2024? The LT version does not support VLIDE.
ladimirabdala
in reply to: pendean
Dear Pendean,
Thanks, but in my case not works.
Take a look in the picture below:
And when I clicked in the link, the button in the page not works.
Nothing happens in the button "Install"
DarrenP
when you click install
it should have opened up this dialog
then clicking on get it now will take you here: https://code.visualstudio.com/download
DarrenP
ladimirabdala
in reply to: DarrenP
Allright, I installed the VS Code.
And works well. 😊
Now I can open the LISP files. 🤗
My question is:
-Can I open with the old IDE LISP?🙄
Like this one:🤔
Thanks for all guys.
In fact, the solution is change the variable LISPSYS to zero!
And then you could access the VLIDE editor.
Have a nice day!
Administrator Productivity
