i just upgraded my license manager from 2012 to 2015, i installed it fine, and i requested a new license file, but the server wont start in LMTOOLS utility.
i get the following error
VD is starting, please check vendor daemon's status in debug log
Hi
Thanks to participate Autodesk Community!
I think you may have mutiple lmtools running at the same time. Please open windows Task Manager, check if there is lmgrd.exe process running, if yes, end all of these processes, then reopen Lmtools and start the service, see if works.
If still fails,you may need to upload the server status and debug log file to check.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Hi , thanks for the reply
my problem was, i didnt realise that the latest network licnse manager v11.12 wont work on server 2008!!! so i installed it on a 2012 r2 server this morning and it started successful !!!!
Hi emily, i also gor the same problem as Sean. Do you have any idea to resolve this problem? Thanks
I just ran into this problem as well with a Windows Server 2008 R2 installation, but I fixed it when I realized the hostname of the server didn't match what was in the license. Once I fixed the server's hostname, it worked correctly. 🙂
Welcome to the community...
You need to go under config services tab of LMTOOLS and attach the "debug" log file here so we can review it.
Mark Lancaster
& Autodesk Services MarketPlace Provider
I have the same issued. When clicking 'Start Server' the following message appears "VD is starting, please check vendor daemon's status in debug log". Where i would expect to see 'Start Successful'.
Any help would be greatly appreciated. I have attached my Debug.log file.
Liam.
it worked.,,,,! when i did ending the process of all daemon related programs in Task manager.
Thank you
