Installation & Licensing
unknown property: visual style mode in undefined
9 REPLIES 9
Message 1 of 10
8333 Views, 9 Replies
Hi Friends,
I have installed 3ds Max Design 2014 on my pc. but there is a problem with interface. i cant see the vieports.
if right click on view port it is showng message "unknown property: visual style mode in undefined"
Please help me.. i think it is script error
Bluefox
9 REPLIES 9
Message 2 of 10
Steve_Curley
It will be a script error - in response to a situation which shouldn't happen. Please post your system specs (OS version, graphics card details etc).
Did you install as Administrator? Run Max at least once as Administrator before trying to use it with an LUA? It sounds like Max is simply not configured correctly, or your system is not suitable. Won't be able to tell without the details.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Message 3 of 10
dianabluu
It's been a year since I put this question, but will answer for those who read this post for help. It seems that your PC is not powerful enough to process graphics. have to change the "display driver" comes to: Customize> Preferences> Viewports> Choose driver>Nitrous Software> OK> OK
Restart 3ds Max, with this must have solved your problem with the Viewports.
P. D. Sorry for my English, I'm still learning.
Message 4 of 10
in reply to: dianabluu
hello , i have the same problem and i've tried your solution but it doesn't seem to work. my system spec is : intel core i7@2.1Ghz 8 gb RAm Nvidia Gforce 630M
Message 5 of 10
THANK YOU! ❤️
Message 6 of 10
Thankyou so much. I tried changing it to direct 3d and open gl because in other forum i saw nitrous causes issues, but even in the rest 2 it never woked. But when I saw your post just thought will give it a try and it worked..... Thanks a ton
Message 7 of 10
thanks for the solution.
It worked
Message 8 of 10
Hi there, I have the same issue and see that solution proposed didn't work for you.  It didn't work for me either.  Where you ever able to fix the issue?
Message 9 of 10
Kudos.it's worked very well. naah,,, dont worry abt the english.....u helped
Message 10 of 10
Thanks a lot!!!!!!!!!!!
Administrator Productivity
