AS I'm now on Eagle 9.2.0, I've seen a installing method which is to create a new installation of the product every time. This produces a new folder with the new files.
I choose instead to use a single folder called, e.g., \Eagle.
When I check on my Apps and Features Control Panel I see already 5 installations of Eagle on my computer (I'm using the product since 9.1.0), which every installation using about 500 MB of space.
How could I get out of these previous versions installations?
In the forum somebody suggested to simple update the product
Alfredo Arizaleta
HI @ajarizaleta
Try using the Microsoft Fix It tool to remove them:
Microsoft Fix It tool:
Install this software and then look in the list for the Eagle and uninstall it there.
Did you have a solution since then?
I'm on 9.4.2 and I have all the old versions since 9.3.0.
Best regards,
I've been using Autodesk Eagle happily for a month now, and this is the first time Eagle notified me about a new release (9.5.2). After starting the installation manually (instead of letting the program update automatically like Fusion 360 does, which I like very much), it asked me in which folder to install the new version. Now I have two folders of Eagle, 9.5.1 and 9.5.2, which occupy 1Gb of disk space. Besides the fact that every update creates a new installation folder, I wonder why the standard installation folder isn't located in the "Program Files"-folder like almost all other Autodesk programs. Can I just delete the previous installation folder of Eagle without any consequences?
