Installation & Licensing
Unable to Open AutoCAD, says missing .NET Component. Unable to uninstall
18 REPLIES 18
Message 1 of 19
20128882
837 Views, 18 Replies
Despite multple attempts to uninstall AutoCAD, it still shows up onthe Apps anf features register.
I tried installing various MS patches, .NET components V06, V08 runtimes etc.
doesnt help.
It does let me unindtall teh Webviewer 2 that I am advised by teh Autodesk comm to uninstall, instead there is only a repair option. Tried that, still nothing
Woes betide me.
18 REPLIES 18
Message 2 of 19
20128882
in reply to: 20128882
Correction:
"...It does not let me uninstall the Webviewer 2 (Edge)...'
Message 3 of 19
imadHabash
I suggest to follow HERE instructions on how to perform a clean uninstall of Autodesk products on Windows.
Imad Habash
Message 4 of 19
20128882
in reply to: imadHabash
Thanks Imad, I will try this and advise. N
Message 5 of 19
Valentin-WSP
@20128882,
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
Message 6 of 19
p_danaj
Hi, I have the same problem. The above solutions do not help. I formatted the disk, reinstalled the system and autocad civil 2025. It helped, but after 2 days the problem returned. I think it is related to a Windows update. Does anyone know how to fix this?
Message 7 of 19
Valentin-WSP
@20128882 / @p_danaj ,
Make sure you meet the system requirements:
As suggested, follow the instructions for a clean uninstall:
If you are still unable to uninstall, contact Windows Support:
Emilio Valentin
Message 8 of 19
Simon_Weel
Microsoft has a trouble shooter for programs that don't install / uninstall.
Message 9 of 19
Juan_Ortega57DLF
Message 10 of 19
20128882
in reply to: Juan_Ortega57DLF
I fixed it, Juan.
Just re-installed it.
It's messy and the uninstallation process is patchy and incomplete, but simply installing the damned thing anew fixed it.
Message 11 of 19
Juan_Ortega57DLF
I have uninstalled and reinstalled 2025 three times and still the same message.
[cid:image001.png@01DB3090.EA13ED80]
Message 12 of 19
Did you do all the things described in the previous posts?
Message 13 of 19
p_danaj
Yes, after reinstall all, I also install this package:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Unable-to-run-Auto...
I fixed it on two computers.
Message 14 of 19
mdavis22569
HI @20128882
I would recommend putting in a Support Ticket. The article for a lot of users isn't working for 2025 software. I'm seeing about 10 tickets a day for 2025 AutoCAD and LT.  It seems to be due to a Windows update.
2024 yet works fine ...
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Unable-to-find-whe...
Mike Davis
Message 15 of 19
20128882
Hi All,
Please excuse the delay in my response.
thank you all for your responses.
Short answer: I fixed this issue by uninstalling whatever the heck the OS permitted me to uninstall of AutoCAD (and Autodesk and anything else with the Auto-moniker) and carried out a full Install, and it worked.
FYI, The attempts at patching with Runtime this and that bore no fruit.
Message 16 of 19
20128882
Post-Script
I also did a system restore to a point preceding my (somewhat hasty) uninstalling of webviewer etc  that caused this issue at the outset.
So, my observation, for what its worth is, is to not mess with MS processes if I want to keep AutoCAD functioning normally.
Message 17 of 19
Juan_Ortega57DLF
After trying a lot of things, I followed mdavis22569 advice and I put a ticket in. They fixed it in less than 30 min. This fix was for AutoCAD LT 2025.
Message 18 of 19
mdavis22569
What did they end up doing @Juan_Ortega57DLF
Mike Davis
Message 19 of 19
They did a few different things through the CMD command. All I can say is that all they did was above my pay grade and they did not do/redo any of the things I had done trying to fix the problem. I'm glad I called them. There is no way I would have ever figured out on my own.
Administrator Productivity
