I downloaded Maya 2022 educational version. When I tried to launch the application, I was being prompted to the image attached here under.
Solved by natasha.l. Go to Solution.
Hello @RAJA_74,
This is normal behavior just select "Sign in using your Autodesk ID" use the email and password associated with your educational Autodesk Account. Newer versions of Autodesk products are activated online by signing in with Autodesk Account credentials, so make sure you have an uninterrupted connection to the internet.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Bellow, mam,
After signing in is it compulsory to be online while working on Maya?
Can't I work offline, after signing in?
If new products are if this nature, may I download the older version to work on offline on line?
Sincerely yours,
RajKiran.
Hello @RAJA_74,
Please review the Autodesk Terms of Use. If you are a active subscriber you have previous version rights this would allow you to install a previous version the oldest being 2018, but it still requires an internet connection to validate your subscription and access offerings.
Autodesk Terms of Use:
"Some Offerings may cause Your Electronic Devices to automatically connect to the internet... "
Natasha
Helpful Links:
