Installation & Licensing
Two autocad version on one computer
2 REPLIES 2
kpere224
907 Views, 2 Replies
Is it possible to install the student version and the full version of AutoCAD on the same computer without any issues?
Tags (3)
Labels (3)
2 REPLIES 2
JuanYusta
in reply to: kpere224
Hi @kpere224
If it is the same version of autocad (year), you would have to install it only once and once inside the program make the account change.
If they are two different versions of the program, they work completely independent.
How to change licence type inside AutoCAD:
https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/ENU/Autodesk-NetworkAdmin/file...
leowarren34
Hi @kpere224,
Whilst you could get it to work, from a compliance side, it's a mega nope.
You must keep your educational and commercial files separate otherwise you will end up in a lot of bother if you get audited. Whilst you could use separate user accounts, personally I would not touch your educational license or files created with that license since the files contain metadata that can spread into other files, marking them as educational which is bad for compliance.
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
Administrator Productivity
