Installation & Licensing
Troubleshooting Revit 2020 install
2 REPLIES 2
221 Views, 2 Replies
I had installed revit 2020. It was working however, I could not access the materials or content, even though the content and material libraries showed as installed.
I have not uninstalled revit 2020 but a bunch of side applications remain.
I have a licensed revit 2017 installed.
What do you suggest I do now if I want Revit 2020 to work normally ? Should I just try re in stalling it ? (material and content libraries showing as already installed in the installation menu).
Or should I uninstall any revit 2020 associated program and try to do a fresh install then ?
I will try to keep practicing on my revit 2017 before I waste more time with this
Thank you.
2 REPLIES 2
leowarren34
I would try to repair the install first, if that fails:
Uninstall using MSFixit: https://support.microsoft.com/en-gb/help/17588/windows-fix-problems-that-block-programs-being-instal...
Then reinstall as admin using browser download: Download from http://manage.autodesk.com/
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
in reply to: leowarren34
Thank you, I will try it now.
Administrator Productivity
