Hi sorry to pester I am trying to download inventor 2016 onto my mac but it is not even loading up the screen, has anyone else had this problem?
@Anonymous
Welcome to the community..
First Inventor doesn't run on a MAC OS unless you have Boot Camp or Parallels Desktop installed. Do you have that?
If you do and are having trouble, we would need to see your installation log file . We can only speculate what the issue at this point. So post your installation file or I will assume its just failing due to the method you're using and you should follow these steps
Download and install per:
1. Access the Autodesk Virtual Agent and follow the download links to your product.
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Follow the installation steps for your product
If you want the full recommended installation steps, click on the installation link in my signature.
However if the installation does fail using this method, please post your installation log file here so we can review it. Posting info: Sometimes installation log files contain personal information such as your serial #. Prior to posting your log file please make sure to remove such info.
Good luck on your installation and report back on your progress.
Mark Lancaster
& Autodesk Services MarketPlace Provider
Hello @Anonymous,
As @Mark.Lancaster mentioned Inventor does not run on a Mac, it runs only on a Windows system. I have included a article showing what products are compatible on a Mac operating system. http://www.autodesk.com/solutions/mac-compatible-software
Please review the following information:
System requirements for Autodesk Inventor 2016
Also, check this out if you are considering using Bootcamp or Parallels https://forums.autodesk.com/t5/installation-licensing/mac-bootcamp/m-p/6847742?nobounce#M171260
Thank you.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
I downloaded Revit LT on my mac, I have parallels with Windows 10. After downloading the 4 files, I open them up for Extraction. A box opens Autodesk Self - Extract, but it never starts initializing. After 30 seconds or so, the box disappears and nothing happens.
Please help.
How big is the C:\Autodesk folder?
Also, if you go into the C:\AutoDesk \ Revit LT folder ...to you see a Setup.EXE?
If so click on it
