How can I get evaluation version of Autodesk CFD?
Solved by karol.suchon. Go to Solution.
Solved by mdavis22569. Go to Solution.
Sure, the easiest way is to ask your Autodesk partner for it, he should be able to help you with generating that one.
BR
Karol
Hi @pics.munmun
Try this:
https://www.autodesk.com/products/cfd/free-trial
@karol.suchon You might want to give a link or more info.. Whos' their Autodesk Partner? So you mean a reseller? Or?
A trial version of CFD does not allow to use own model.
The evaluation license allows us to do it. By Autodesk Partner I mean a reseller.
You could also find them here 🙂
https://www.autodesk.com/partners/locate-a-reseller
