An Autocad LT and Revit suite 2020 with the maintenance plan license was uninstalled from a computer and we installed it on a different computer. I understand now that the license is still active in that computer. What can I do now to straighten this out so we don't have too many copies?
Solved by Mark.Lancaster. Go to Solution.
Activation of perpetual license can't be restored.. If you used the LTU (if it works) that would be different, but the activation count still is out there for your old machine..
I would recommend (on the other machine) that you perform a clean uninstall per these instructions.
Also I would recommend removing the existing license information per this instructions.
Mark Lancaster
& Autodesk Services MarketPlace Provider
