Transfer license utility
mcfireprotection
Message 1 of 12
mcfireprotection
If I need to uninstall and reinstall AutoCAD on the same computer to try to fix erros, do I need to use the License transfer Utility?
Replies (11)
Message 2 of 12
pendean
Community Legend
Community Legend
What year version of AutoCAD is this please?
Message 3 of 12
mcfireprotection
Message 4 of 12
mcfireprotection
the Export didn't go though. Autodesk sent me to a separate window, https://profile.autodesk.com/personalinfo, that does not show any information.
I tried to reinstall AutoCAD and I received an error message that the transver was still in progress.  I waited overnight.
now it won't install because it says the export is still in progress.
Autocad wouldn't run before the uninstallation since an error message appeared stating the export was still processing.
Now what?
Message 5 of 12
mdavis22569
If you're on W10 or 11 it's likely why it's not working.
Is the license still even valid?
Mike Davis
Message 6 of 12
pendean
Community Legend
Community Legend
May I ask, was a repair or reinstall of Aut0CAD 2015 not an option? Handled in Windows through Control Panel. Neither required the use of the LTU.
Or did you have to do more to fix the issues you faced, like reformat the PC/reinstall WindowOS or upgrade the PC?
I've never know the LTU to be used from and to the same exact PC before.
Message 7 of 12
mcfireprotection
I've already ran the license transfer utility using Windows 109 and it
worked fine on this Windows 10 machine until I tried it last week before I
uninstalled and reinstalled to fix a printing error. AutoCAD 2015 has been
running on this Windows 10 machine without any problems before this.
Yes, the license is still valid. It's a perpetual license.
What are my options?
Message 8 of 12
mcfireprotection
I didn't know that was not required.  Repairing did not solve the problem.  I didn't know what to do .  I thought uninstalling would require a LTU.  My mistake.
Message 9 of 12
mdavis22569
I haven't seen the LTU work properly on W10 (in my experience)
Why not just reactivate it manually:
https://help.autodesk.com/view/INSTALL_LICENSE/ENU/?guid=activate_and_register_your_product_evergree...
https://www.autodesk.com/support/technical/article/caas/tsarticles/ts/3mH3zzAYu3yHZNP41qP3qY.html
Mike Davis
Message 10 of 12
mcfireprotection
It's working now. I sent in a case and they must have fixed it. 🙂
Message 11 of 12
mdavis22569
likely just needed their "permissions" to activate..
Glad you're all set
Side note: watch the c++/NET updates for Windows 10 and 2015. I see a lot of issues when Microsoft does an OS update of these.
Mike Davis
Message 12 of 12
mcfireprotection
Thanks. Updates are a pain. They seem to always disrupt something.
