OK. So I was using Maya 2014 on my computer. Oh joy! Then I had a serious problem with the computer and all hell broke loose, dead drive. So I had to reinstall everything. But Maya 2014 won't work anymore. 2016 is OK but I can't stand it. Aweful version.
So here we go:
I'm on a Mac, by the way.
When I try to install 2014, I get this error message three times during installation:
RegisterPkg Error An unexpected error has occurred during execution of the main script. ZipImportError: can't find module 'uninstallerSQLDB'
Then after installation I get this: A licence error has occurred, contact tech support. Error code is 110.
I did some research on this. Apparently I need to completely uninstall 2014 and make sure I install service pack 3, which I thought I did already.
The instructions to uninstall the software are to trash the Maya 2014 directory in the trash and run two commands in the shell:
adlmreg –u S 657F1 2014.0.0.F
adlmreg –u N 657F1 2014.0.0.F
But I get this error message:
Solved by Otto. Go to Solution.
Yep! Service Pack 5 was the answer. I still had the zip errors but Maya is working fine so I don't care. Thanks Otto!
