Student license reactivation doesn't work
Message 1 of 11
Hello, everyone!
I'm a lecturer at Polytechnic of Rijeka. My 3-year license has expired and AutoCAD keeps warning me for the last few days to reactivate it.
Every time, I click ACTIVATE button, and it says "Congratulations! You have successfully (blah blah...)". However, next time I start AutoCAD it *AGAIN* warns me that the license has expired and I need to reactivate it. What the...???! Smiley Mad
In the attachment is the registration information stored on my Mac (I've crossed the codes out, this is just to show that the product actually IS activated).
Replies (10)
Message 2 of 11
Otto
Hello emil.prpic and welcome to the Autodesk community!
It looks like your license has expired. The following article(s) should help you resolve the problem:
Reactivating your Expired Subscription Home Use License
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
Message 3 of 11
Darin.Green
Log back into the education community and generate a new code if needed. Your contract needs to be renewed (even though it's free). The contract only last for 3 years, then a new one needs to be created.
If you have trouble with this, please reach out to the education support team
If this information was helpful, please consider using the Accept Solution
Message 4 of 11
Thank you for your reply. Where *EXACTLY* do I need to log in to? I did log in to register.autodesk.com and entered everything manually. Got another activation code, AutoCAD said it's activated, but, after restarting it, again it says the license is expiring.
I can understand that I need to do something somewhere, but why don't I get a clear message what to do? This is rediculous... 😕
Message 5 of 11
Darin.Green
This is a public community where users are helping users... We're not Autodesk.
Here's the education community site
If you choose a product and the serial number is the same for the version you choose, delete the contents of this directory and try launching the application again...
C:\ProgramData\Autodesk\FLEXnet
Message 6 of 11
Thank you. I apologize if it seemed like I was criticizing you. I wasn't. I was critisizing AutoDesk for messing up such a simple process.
I logged in to the education community, but now they don't offer AutoCAD for Mac at all??! Smiley Surprised Windows only...
Message 7 of 11
Darin.Green
I understand.
AutoCAD for MAC is there... Make sure you choose All Products or use <<this link>>
Message 8 of 11
Thanks. I've found it. Serial number is the same.
I've found a folder
/Library/Application Support/Autodesk/Adlm/FLEXnet
I suppose that should be Mac equivalent of what you suggested that should be erased.
Inside I have:
- a 23MB file named preparchive_11.11.0.yaa
- a folder named bin (as in "binaries"), and inside it:
  - 475 kB unix executable FNPLicensingService (I'm not sure that it's wise to delete it)
  - 5 kB unix shell script install_fnp.sh
  - 1 kB unix shell script toolkitinstall.sh
Does it seem at least remotely similar to what you have on Windows?
Message 9 of 11
Darin.Green
Sorry, I forgot this was for a MAC... Delete the ProdInd_UserInd.cur file from /Library/Application Support/Autodesk/ADUT/
Message 10 of 11
Thanks again for your effort and support. Finally, it turns out that I simply CANNOT extend my educational license on an old version. I need to request a new license for a newer version. I suppose it would have killed them if they put that in plain text, in the expiration message itself… 😕
Message 11 of 11
Darin.Green
I figured that was the case. That's what I suggested in my original post to you. Oh well... Happy to see you're back up and running!Smiley Wink
