Hi I am a student using Mac OS High Sierra. The Autodesk Educational Community only provide AutoCAD 2015 for MacOS and it was not work for Mac OS High Sierra. Then I have downloaded the AutoCAD 2017 and it can be installed and work (as a trial).
But the problem is I cannot get my student license because the serial number and product key were not showed/ provided. Autodesk only provided the serial number and product key of AutoCAD 2015. What should I do?
Solved by natasha.l. Go to Solution.
Solved by Mark.Lancaster. Go to Solution.
That can not be, as a student you have the possibility to download and use the latest version on AutoCAD. When you log in to Autodesk with your university e-mail addy.
You need to be able to select versions of Autocad. As soon as you have selected these you will immediately get the product key (Serial)
Best Regards
Dill Khan
@Anonymous
This isn't valid
Your Serial number will be the same for all 2017's ...
You'll find it here in your account manager:
https://manage.autodesk.com/cep/#
Then you'll have the following Product key:
Autodesk AutoCAD for Mac 2017 | 777I1 |
You can get the download for HS 2017 here:
I have the same problem. the above solutions are not working
@Anonymous
Are you trying to install AutoCAD For Mac 2017 on high sierra? If so you need the 2017.2 version which can be found here: https://knowledge.autodesk.com/support/autocad-for-mac/troubleshooting/caas/downloads/content/autocad-for-mac-2017-full-version.html
Mark Lancaster
& Autodesk Services MarketPlace Provider
Hello @Anonymous,
In addition to the download link for AutoCAD 2017 for Mac OS High Sierra that Mark provided, you will need to go back to your educational community account.
You can try to review the following post to go back to your account & select this version so you have access to it & activate Steps for Setting-Up Student Software.
Please “Accept As Solution” if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Hello @Anonymous,
Please let us know if you have resolved the issue & need some more suggestions.
Remember to “Accept As Solution” if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Natasha
Helpful Links:
