All,
A client of ours is using standalone versions of Autocad and when their users open up a drawing it is asking for a username and password as if they are using a network license. They cancel the popup and continue working but it is becoming annoying since it happens every time they open a drawing. Does someone have a suggestion on how to stop this issue from happening. I have enclosed a screenshot of the popup.
Try Resetting the Settings : To Reset the Application to the Default Settings
SALMANUL FARIS
Check this solved thread on something similar : How to stop asking proxy at start
SALMANUL FARIS
This has nothing to do with the licensing of AutoCAD. They are tryng to connect to a given server needing log in information. This is not Autodesk related.
Mark Lancaster
& Autodesk Services MarketPlace Provider
Mark what do you think my next step should be since this popup is still popping up? LOL
Based on a search. That IP address is showing to be a private internal network address. I would start a command prompt in windows and type ping 172.17.0.8 and see if anything comes back.
Mark Lancaster
Thanks Mark. I will post any results from my client and keep you informed.
