Installation & Licensing
user5327
94 Views, 1 Reply
software login issue
Steps to reproduce
Stuck in a loop of entering login information into Fusion 360 desktop.
Expected results
login to software and normal use it.
Actual results
always inside the loop about: (click log in -> log in at browser -> wait fusion 360 loading -> show log in button)
URL where issue occurs
no/real/url
Browser
Chrome
OS
Windows
1 REPLY 1
Please follow the steps mentioned below:
  1. Reset with the Service Utility
    • Open the Fusion Service Utility. See How to Launch the Fusion Service Utility
    • Select Reset Fusion.
    • Check the desired options (Keep offline user cache, Keep user credentials).
    • Select Yes, Proceed.
    • Fusion will delete the files.
    • Manually restart Fusion.
  2. Create a Team Hub
    Join or create a Team Hub using the Fusion Team Onboarding site. Then try the sign-in process again.
  3. Set the system clock manually:
    • Go to Start > Windows Settings.
    • Select Time & Language.
    • Select the Date & Time tab.
    • Set the Time automatic: On.
    • Set the Time zone automatically: On.
Administrator Productivity
