I'm having some issues getting the silent install for AutoCAD to work.
We used to use SCCM and everything worked great. We moved over to a different product, and sometime after that the silent installs stopped working.
I've gone through the steps to create the install package for AutoCAD 2021, but when I try to use the setup.exe and .ini file that it generates to install the software, nothing happens.
This is an example of the command line i'm trying
"C:\Users\username\Desktop\AutoCAD2021\Img\Setup.exe" /I "C:\Users\username\Desktop\AutoCAD2021\Img\AutoCAD2021.ini"
There is no silent switch because I just wanted to get the software to open, which it did once but won't do again. If I just go click on the setup.exe file, nothing happens either, just a security prompt to run the file.
Any ideas?
