XPost from the Showcase forums, but I see it doesn't get as much traffic as this does:
I just installed Showcase 64 bit on to Win 7 - 64 Pro and I see the following:
Error Report - Required Value Missing
An Autodesk product failed to send the required value for SERIALNUM
The error report sent to Autodesk may be incomplete.
And the software won't install. I input the Serial Number and it was accepted during installation.
Solved by david.lau. Go to Solution.
HI Eric,
Can you please check the Windows Features and make sure that .net framework is enabled. If so what version is installed?
Start button -> Control Panel -> Programs -> Turn Windows features on or off
This maybe the issue...and solution.
Hello All,
I apologize for revisiting this issue. The link under the "up and ready" page provided by David Lau seems to be broken, so I don't know which patch you guys used. I am getting this error message for Nastran In-Cad 2017 and I can't find a solution for it in the forums.
Any help is appreciated,
Derek
